???Obvious. Will the additional LCD controller allow a dual-mono configuration?
4490 mono mode is triggered using mono bit and sellr bit in a software command. Is the optional Jlsounds lcd controller able to trigger mono mode on 2 separate 4490 boards to achieve a dual mono configuration as done in Hummingbird with 4495s?
Wrong.. for balanced output use LME49724..
Is this going to be offered as a PCB, or can we modify a DIP8 adapter?
They are not compatible with LME49710 and the PCB shows Power on pin 7 so that is not going to work for LME49724.
The LME49724 looks like a very nice device tho.
Sorry for my late answer, lately the time is not enough
Regarding for AK4495 I'll open a new thread.
If the firmware version of the XMOS board is greater than 3.06 - yes...what happens with old XMOS_AK4396 combo, is there support for native DSD..
For now there is not such an option.@joro_s is there any possibility to control DAC chip directly thru i2c using an external controller?...
Yes, you can switch just the DACs, no problem at all. Depending from your version of XMOS firmware, there might be some clicks. The necessary power supply for the AK4490 is one 5V, my recommendation is one to use clean external power supply.... Can I just drop the 4490DAC in instead of my 5102? Do I need additional power supplies?..
That’s correct. Soon Lyuben will post scheme of the board. Without this board the DAC will work only with service settings....
I just figured the €16 LCdisplay board is required to do the settings (filters + volume)...
The AK4490 DAC has differential outputs and LME49710 board and DRV603 board make the differential outputs to single ended and of course the reconstruct filters. On the AK4396 board the Opamps and the reconstruct filter were on the same board, but there ware plenty of diyers who remove the OpAmps and use directly the outputs of the DAC, that's why I decided the filters to be on separate boards. DRV603 is lower class than the LME49710, but it manages good with 5V PSU (it's the maximum ) and there is 2V RMS on the output and its' mute is good enough. The LME49710 board works form +-12V to +-15V....
And there are more options (DRV603 and the LME49710 filter board)
The USB part is little hungry 330mA, I recommend 4V – 4.3V in order the board to be cooler, as for the DAC and oscillators 5.1V 120mA.Id like to use a few reflektor shunt supplies. What are the power requirements of the USB and AK4490?
Later today I’ll open a new thread about the Hummingbird dual ak4495 DAC with all detailed information.I can't wait for Hummingbird dual ak4495 DAC... any out date prediction?
It's not right I to make the comparison, I can only tell that the dual mono has its' advantages..
What will be the SQ/performance differences between Hummingbird and single 4490 DAC board? ...
On the AK4490 board the outputs are directly from the modulators from the DAC chip and they are balanced...
Does the latter have balanced output? ..
On the AK4490 board - right now, without interventions on the boardCould the output stages of both DACs be replaced by a se/balanced tube buffer/line stage amplifier?...
Sorry about that, you can always contact by mail, where Lyuben is faster than meHay guys, do you also have problems to conntact with Joro?...
... AK4495 seems better, have more ...or section and post the links. Regards, Joro
Where can I see firmware version..
Is there some option for change and flashing new XMOS firmware..
Regarding the update - there are three scenarios:
1. Using a SPI programmer like this one: 24 25 Series EEPROM Flash BIOS USB Programmer CH341A with Software Driver | eBay
2. I can send you a new memory IC.
3. Slowest and expensive scenario - you can send me the board for update.
Regards,
Joro
I'll test this firmware for clicks with the AK4490.Find it, v1.58..
Is there a possibility for firmware upgrade..
Regards,
Joro
For AK4490 I will certainly take another XMOS board..
This one with old firmware stays with AK4396 board.. v1.58 have some clicks..
I will choose first option only if it is 'idiotproof'.. second one also looks fine..
http://jlsounds.com/uploads/AK4490_board.pdf
http://jlsounds.com/uploads/LME_board.pdf
http://jlsounds.com/uploads/DRV_board.pdf
LCD control board still missing..
On the XMOS board there are three 3.3V LDO LP5900, one 1.8V LDO MCP1700T-1802E/TT and one 1V LDO MCP1825T distributed as follow: one LP5900, one 1.8V MCP1700T and one 1V MCP1825T are before the galvanic isolator (i.e. USB part) and two LP5900 are on the clean side for reclock and the oscillators.
The LP5900 doesn’t like voltage above 5.5V and that’s why one needs to use pre-regulator on 5V. Between those two, the LM317 in mode with capacitor between adj and gnd pins is far better.
Regards,
Joro
If I correctly understand , the clock (XMOS board) doesn't have a individual regulator, and it requires the maximum clean power? Or MC7805, LM317 will be rather?
Regards,
Joro
- Digital Line Level
- XMOS DSD 384 kHz / 32bit USB
