carpenter said:So there is no need for large value caps in the filtering dept? That's very cost effective.
It will depend on a circuit. Typically 1000-4000uF should be placed before regulator and at least 47uF after. I used 10uF as it worked best with the battery connected to the output.
In my CD player, I use 2200uF before and 1000uF after LM7808 regulator, as those values worked the best.
carpenter said:Another thing: the regulated pcb requires raw DC, yes? Can the raw DC be obtained from the same pcb as the regulated supply? There may be some Jerri-rigging necessary......
The regulated PCB takes AC directly from transformer (if you use on board rectifiers)
Yes, the large resistors are only used for power amp aplication and not needed with regulators.
Any standard trimmer will fit here, you just need to form the pins properly (center and one of the outer pins connected together). After setting required voltage a trimmer should be replaced with fixed resistor.
Suppose to be F1 PCB thread.
I posted this in F4,
suppose to be in F1 PCB Thread..
These are F1 PCB's
Admins, Can you move above quoted post to relevant thread !
PCB Image file is 2.5MB Post #613
File contains images of two sides for Both PCB (Amp and Power)
file size is 2.5 MB.
I have boards in stock..
-suds
These are F1 PCB's
Peter - Paypal added for 2 more stereo F4 Amp boards. Final tally is 4 Amp and 4 PS boards. Thanks! Tomtms0425 said:Peter,
Hopefully not too late! PP sent for 2 stereo F4 boards and 4 PS boards.
Thanks,
Tom
