@DartmoorDad. Thanks very much for that info! I will report back when I have had a play.
I've now got it running so that the rca is the default input - by clicking off the mic input and then 'downloading' to 'flash' (aka the amp).The only problem is: default input is bluetooth, not analogout rca input
The annoying LED still flashes however to tell you that BT is not connected. That can't be turned off in the software.
I have been having bru5 for the past few days.
Just like few forum members pointed, I had problem with only 1 channel working. L&R being mixed up. Then it worked alright!!!!
I was driving a passive subwoofer. DSP software was very helpful. I am no expert on DSP but somehow managed to set the low pass filter and input gain and bru5 met its objective.
The biggest issue: it gets too hot quickly.
Perhaps its due to the 48v5a power supply of Aiyima.
Need to check this with something like 32v/24v supply.
Would be helpful if members can comment on this heat issue.
#wondom #bru5
#wondom #bru5
