What tubes for a OTL tube amp?
To Mr Popilin,
This is what Ralph Karsten from Atma has to say about preconditioning the tube's,
"If you are dead set on using American tubes, it is possible. The cathode resistance must be increased to a minimum of 5 ohms 5 watts (which is a good idea anyway). If the tubes are NOS they must be preconditioned for 72 hours to minimize arcing."
So i'm not sure what to do, preheat or not????
To Mr Popilin,
Thanks Buizerd for your investigation. Please if is possible to attach the link for read the entire article.
Best Regards and sorry for my Mad FACE
Welcome to Menorca. Many dutch come this year to (the)(My) Island.:)
To Mr Popilin,
In old/NOS valves, the getter should be reactivated, then preheat is a must.
But not as proposed, ie powering the heater with no voltage between the cathode and anode.
Follow the advice of Wavebourn, is no coincidence that he is one of our superheroes in the forum.;)
My buddy Dady, said to me he would make an experiment with a thermocouple to heat the valves in an oven, to determine preheat temperatures and times.:)
Driver V4 Voltage
In the final MullardEL34 schematic, post 247 and attached, the effective Vpp voltage across the driver 6SN7 V4 is 620V. If the grid bias voltage on the final 6AS7s is in the range of -65V to -75V for Class A (say -70V), as delivered at the cathodes of V4, then the net voltage across V4 is about 380V. Seems awfully high as the 6SN7 spec sheet says 300V max. What am I missing?
G'day TV7,
You just up the road from me.....
It'd be easier to read the thread, there is so much here, first 6-8 are really interesting, currently sorting my trannies for a set of M60 clones as the NO NFB attracts me.....a lot. I have a set of other OTL monoblocks in build stage as well when I came upon this thread. I could give you basics but it's worth the read.
Pm me and could have a yarn.
Drew.
As you can see in my avatar, I have them up and running for a while now, and i'm very satisfied, I have only a very small hum in the background, but that's because I do not have a balanced preamplifier.
Is it perhaps possible to share your talk with Ralph with us, we don't see him so often on this board lately.
