"WHAMMY" Pass DIY headphone amp guide
I was wondering whether the idea is to keep the PS for this amp floating, I have not explicitly grounded the circuit to the power earth except the RCA jacks ground connected via .01uF cap to avoid oscillations in the circuit. Since there is no direct provision to ground the circuit via 10 ohm thermistor to the chassis and eventually link to power ground (like other FW circuits), not very sure if this should be implemented...
6L6
Moderator
Joined 2010
Yes 10K resistors would give a comfortable bias
Bias is a function of the source resistors in the output stage, R16 R22 R29 R32, and increasing their value will reduce the bias, as shown on the schematic.
I'd probably try 18ohm or so to start.
