N-Channel said:No doubt you will be leaving the ice behind! Befor you leave, try looking at this website at OnSemi:
http://www.onsemi.com/pub/Collateral/SG3525A-D.PDF
Bon Voyage,
Steve
I'm not nesecarily very sorry to be leaving, but it'l be good to get some time off from school. no ice down south last year at this time for shure
I'l take at look at the site. thanks.
at the time i'm busy goint through the smps tutorial here:
http://www.smpstech.com/tutorial/t00con.htm
I'm surprised not to see this:Linear Technology App Notes or this LT Design Aids; Some of the LT app notes are classics. And although it's been a while since I used the tools, they worked very well.
hehe, dont hold your breath
i'm testing out a smps in it's simplest form, using an external signal generator and a low voltage source. just to get the feel for it.
i'd like to ask someone of the knowledgeble here the following:
what is the deffinition of a halfbridge and fullbridge smps?
and when using an IC for switching controll, how about voltage suply?
is a dropdown resistor used? are there high voltage IC's available?
so many questions...
thanks
-Marius
thanks
-Marius
richie00boy said:Half bridge is like a single ended audio amp, full bridge is like a bridged audio amp.
ok, i suppose i get it.
halfbridged it is then.
hehe, thanks richie, i'm gonna do that.
i'm using 2sk1217 for switching, but i'm uncertain as to if it's a depletion or enhancement piece. gonna try it out tomorrow, se if it runs. had to go to an extra meeting at work, just home to eat and shower, then i'm back again.
-Marius
-Marius
Your secondary side looks right now, however the transformer will saturate because the secondary side inductor will short it through the diodes during the off-time, thus preventing it from resetting.
Try to find a way to drive the primary in a symmetrical way, for example in push-pull.
ok, the circut is up and powered, though only wierd resoults have arisen so far, and no squarewave is yet connected. gonna troubleshoot a bit.
i altso have taken a few pics for your viewing pleasure
the switching frequency is 25kHz, Vp2p is 2v, the load resistor is 1k.
anything anyone would like to add to this?
i'l keep you posted.
-Marius
-Marius
- Power Supplies
- wanting to get into smps designing and building
