Vacuum Tube SPICE Models
To create your own spice model, the first step is the determination of MU from a reliable diagram. Diagram must include Ug=0V curve.
I took Telefunken pentode and triode diagrams just for example.
The formula for calculation is:
MU=(Ua-Ua min) / Ug
For pentode, the line passes through operating point and the END of knee @ Ug = 0V, as you can see.
Administrator
Joined 2004
Thanks Raj,
This will allow us to determine mu for the model and then work solely with the other parameters - should make curve fitting a lot easier.
I built a prototype of my new phono stage (the muscovite mini) using a 6Z9P-E pentode in the front end and was gratified at how close the measured performance was compared with the spice model predictions. It even sounds good.. lol (The model is a slightly modified version of the one you gave me, kg2 adjusted to reflect real world screen currents.)
Thanks Raj,
I saw, nice.
I know a few DIYers who use E180F in RIAA preamp.
One of them has E180F in pentode mode as input, and E180F triode mode on output (LED bias, CCS mu-out). He is very happy with sound. I adapted the Russian Teflon capacitors for his RIAA RC network. Simply unwrapped AL/Teflon foils to the required value. See atach.
well , I'm dumb .... but that's hardly anything new ..... :rofl:
what I'm doing wrong ?
current from PSU to tube is 8A , but I'm still puzzled where is it going :clown:
Kad tvoj atas proslijedim u LTspice, sve je korektno. Radna tacka: 395V/99,4mA/-11,93V,
Tako da trenutno ne bih znao.
translation:
When your atach I put in LTspice everything works correctly.
So currently I do not know ....
Different I/V curves for different brands of same tube type?
I tried the Joel’ pspice models, and noted that his library refers the tube brand datasheet, for every tube type, so I tried to see how different could be the I/V curves for some different brands of the same tube type.
Surprisingly, I came across with differences in Vp as great as 10% for the same Ip and Vg !
Have a look at the attached graphs, of the 12AT7 from BRIMAR, GE and MAZDA (Phillips).
Ex-Moderator
Joined 2011
I am looking for LTspice model for Soviet 12J1L (12Ж1Л).
Does anybody have ?
Freshly made, just out of the oven ;)
Code:
* Generic pentode model: 12J1L_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Wed Dec 11 14:54:51 2013
*                Plate
*                | Screen Grid
*                | |  Control Grid
*                | |  | Cathode
.SUBCKT 12J1L_AN A G2 G1 K
BGG   GG   0 V=V(G1,K)+0.98709898
BM1   M1   0 V=(0.037076469*(LIMIT(V(G2,K),0,1e16)+1e-10))**-1.4371722
BM2   M2   0 V=(0.51069528*(LIMIT(V(GG)+LIMIT(V(G2,K),0,1e16)/13.197177,0,1e16)))**2.9371722
BP    P    0 V=0.0011571547*(LIMIT(V(GG)+LIMIT(V(G2,K),0,1e16)/25.841588,0,1e16))**1.5
BIK   IK   0 V=IF(V(GG)>0,1,0)*V(P)+(1-IF(V(GG)>0,1,0))*0.0010881412*V(M1)*V(M2)
BIG   IG   0 V=0.00057857734*LIMIT(V(G1,K),0,1e16)**1.5*(LIMIT(V(G1,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+LIMIT(V(G1,K),0,1e16))*1.2+0.4)
BIK2  IK2  0 V=V(IK,IG)*(1-0.4*(EXP(-LIMIT(V(A,K),0,1e16)/LIMIT(V(G2,K),0,1e16)*15)-EXP(-15)))
BIG2T IG2T 0 V=V(IK2)*(0.84036243*(1-LIMIT(V(A,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+10))**1.5+0.15963757)
BIK3  IK3  0 V=V(IK2)*(LIMIT(V(A,K),0,1e16)+5550)/(LIMIT(V(G2,K),0,1e16)+5550)
BIK4  IK4  0 V=V(IK3)-LIMIT(V(IK3)-(0.00064639118*(LIMIT(V(A,K),0,1e16)+LIMIT(V(G2,K),0,1e16)-LIMIT(V(A,K),0,1e16))**1.5),0,1e16)
BIP   IP   0 V=LIMIT(V(IK4,IG2T)-LIMIT(V(IK4,IG2T)-(0.00064639118*LIMIT(V(A,K),0,1e16)**1.5),0,1e16),0,1e16)
BIAK  A    K I=V(IP)+1e-10*V(A,K)
BIG2  G2   K I=LIMIT(V(IK4,IP),0,1e16)
BIGK  G1   K I=V(IG)
* CAPS
CGA   G1  A  0.007p
CGK   G1  K  2.4p
C12   G1  G2 1.6p
CAK   A   K  3.7p
.ENDS
Administrator
Joined 2004
Installing Tube Libraries In LTSpice
OK so you want to install a collection of tube models and their supporting symbols. Note both are provided with no warranty implied or otherwise.
There are two directories you need to locate. LTspice is a 32 bit program and will be installed in program files in xp or Program Files (X86) in Win 7. Locate the LTC folder..
Path to tube symbols is \LTC\LTspiceIV\lib\sym - unzip the tube_sym zip and paste the folder here.
Next step:
Path to tube library is \LTC\LTspiceIV\lib\sub - unzip the tube_lib zip file and paste the file here.
Start LTspice and under the component folder (AND gate on the menu) you will see a folder called 'Tubes' click on this and you will find diode, triode, tetrode, and pentode folders. Click on the folder of your choice and you will get a number of choices. I have lots of triode models and fewer pentodes, tetrodes and diodes. A few models may be funky, but most work ok.
  • Tubes_sym.zip
  • tube_lib.zip
Reactions: 1 user
Quote:
Originally Posted by jazbo8 View Post
<snip> To use those models in LTSpice, you need to manually edit the *.inc files by replacing all the "^" with "**" in the text. I think you will find those models superior to the ones by Koren, Munro, etc.
On linux, it is just to decompress the archive, go into the directory where the inc files are, and run:
Code:
for i in *.inc; do sed -i -e 's:\^:**:' $i; done
