Looking forward to your progress..
I like wood..LOL
Just an interesting picture...
Modified Futterman OTL amplifier - cellai@space.it - OTL Asylum
Reflecting on the picture the 6080 is a tube I had not thought about...
Go on lash it up for fun and have a listen...Then you can assess how hot its going to get and do any tweeks before vacuum packing it...
M. Gregg
I like wood..LOL
M. Gregg
6AS7/6080 is a good one, the amp i sold to pay for this was a PP 6080.
Somewhere in the darkest places of storage i have loads of new PL36 from the TV-era something for another OTL.
Have you tried to hook it up to 16 or 32ohm load and measured it ?
Tells a lot about the outputstage.
I was just looking at this schematic
6AS7GA OTL
They have achieved the drive voltage swing by using 550V on the driver stage..
just wondering about the Mini OTL idea it would have to be fixed bias to get the power from a small size... Mini and power efficient<<< The green OTL LMAO I guess OTL and Green don't go togeather..
I am waiting for your test results ... I don't want to take the fun out of it...LOL
Its been on for 6Hrs so far today.. ..sounds great!
M. Gregg
6AS7GA OTL
Hi M. Gregg, I made this amplifier ( from Glass Audio ) more than 10 years ago - it sounds superb!
This was my first-hand experience with OTL amplifiers > it sounded way better than good 300B SET amp side-by-side... with zero problems regarding dc shift in output stage...
Max
Amp up and running for about 5 min then the filament reg blew
Murphys law OTL amp strikes back again
Try a 3/16 pin in place of the regulator.... it has better current capacity..
M. Gregg
Max
Thank's for the info..
Looks interesting... what was the heat like from the Op tubes?
M. Gregg
It wasn't that bad, surely more heat than average tube amp but still very tolerable in the small room.
Max
Max,
Do you still have the amp?
What happens if you use only 2 or 4 X 6080 in each channel
(is the OP impedance to high ie not able to drive the speaker) wattage level ?
Just looking at a few ideas...
M. Gregg
Hi M. Gregg, I sold that amp years ago in pursuit of even "better" tube amplifiers but it was capital mistake... ( I see that now )
This amp was build as a stereo version with 4x6as7 per channel & at that time I was using Rogers LS3/5a speakers ( 11 ohm ) - in spite of 82.5db sensitivity amp would drive this speakers with ease...
I never used amp with less than 4 tubes per channel because of filament power supply was wired in series per 4 tubes ( about 25V DC )...
I'm busy at the moment with one OTL amp with 6080 tubes, when I have working prototype - I'll let know everybody about it...
Regards,
Max
Regards,
Max
Any news?
I guess you have solved the Reg problem?
M. Gregg
One of the 6J5s has a bad filament, very hungry for current
Have to go storage diving for a new in the weekend.
I just used 7812 with a diode in the leg to lift it to 12.6 then series the heaters...easy overcurrent protection float the ov rail with a 0.1 polypropylene <<< made a big difference in hum reduction.
M. Gregg
The problem when i get some time waiting for components is that the rest get overenginered.
Back to KISS and drive by enginering
I have one 6.3 feed for small signal heater.
MbR735 bridge 20mF 1084.
I suspect some kind of short between HT and filament otherwise the overload protection should save the 1084.
Just for interest,
I have received the CC 330 Ohm resistors, Just waiting for some orange drop 716 to try for fun in the o/p from the PI to 6c33c before I pull it to bits... I will put some PTFE sleeving over the resistor leg before fitting the ferrite bead. Reason is I have found ferrite can smear the sound when in direct contact with the conductor.
M. Gregg
M. Gregg
I use DC for the input tubes and AC for the PI... How did you get it into the box? I know put it in the food blender then pour it in the box...
If i run the 6j5 on ac with the existing voltage ref and only 5692 with dc floating heater.
Have you figured out why it has less hum floating ?
6SN7 usually likes elevated heaters around 50v.
The only thing I can think of, is there can be no difference between heater and cathode voltage because the cap will charge to what ever value it needs to be equal..
I don't know why but with DC and a fixed lift voltage the hum would vary as the tube got hotter with use.. It also created pick up on the grid from the volume pot. With the heaters floating with a cap all this pick up stopped..
I found that when the 6c33cs were pulled out of circuit I could hear any noise from the pre section in the speakers. So its interesting to listen to the OP with speakers connected and no power tubes just to try it..
(the PI return to supply creates this)
- Tubes / Valves
- Vacuum Tube OTL power amp!!
