using a driver with a Q factor higher than 0.7~1.0 is essentaily applying mechanical EQ.
OK .... No electrical EQ .........
here's a 15" P-Audio SN15c coax woofer with qts ~0.37 on a 2' wide by 3 foot tall baffle - subjectively there was adequate bass and good control
(hi Hitsware!)
(hi Hitsware!)
My recent build, 4-ch in Hafler circuit (with outer speakers playing differential signals), all dipole except the up-firing super tweeters for the top octave.
Karlson style lens is added to the HF unit later:
More info here:
http://www.diyaudio.com/forums/full-range/271011-rockin-kazba-dipole-k-aperture-z-baffle-dipole.html
More info here:
I believe personal preference also plays a large role here. That kind of response would sound thin to me on my system.> subjectively there was adequate bass and good control
Hey ! .... Freddi
YES ! It's sometimes mind-boggling how perception transcends theory !
edit: Only if Fs is lower than baffle rolloff ..........>There's still dipole loss to compensate.
Not if you use high enough Qts
AND!
High enough Fs
Assuming high enough Qts :
Only if Fs > baffle rolloff and desired F3 is compensation needed.
"Orion"-esque Planar OB
www.serenityacoustics.com/products/thesuper7.html
And please no more 'theories...' ... we wanna DROOL
No, it's not for cancelling vibration force.
It's for making the dipole path length larger - increasing the distance of the front/rear wave cancellation.
The air between 2 woofers moves back and forth as a bulk without the behavior of soundwave. So, it should be quiet here. But there could be a weird sense of airflow. No problem in the normal listening position.
If the woofers operate in the same polarity, it'd become a quadrupole. For producing bass, the efficiency is too low.
So the cones move in the same direction (it will not cancel forces)?
Wow!
That's beautiful !!
Yes, they are beautiful.
Made in Slovenia, by Miro Kranjec. Link of other products: SoulSonic Speakers
5 x 12" focused OB arrays (unknown driver)
found on post 309
http://www.diyaudio.com/forums/mult...-sound-single-loudspeaker-31.html#post2907305
he last posted in 2011...............
found on post 309
- Ultimate Open Baffle Gallery
