Thanks Alex, that is what I thought but wanted to make sure. Not reading or speaking French, I am slowly going thru the thread on homecinema.fr now, but hadn't seen anything to lead me to believe otherwise. There wasn't a board layout for the external supply on the 1st post so I couldn't tell whether it had been updated or not.Hello,
Unfortunately not as I reused the boards here that were designed by Flat for the UGS all inclusive (the full relay version) and this was single primary wiring only.
But those pcb are not difficult to modify, I remember to do exactly what you want to do, with a dual primary transformer by drilling few additional holes on the pcb to accommodate the additional transformer pins.
Or maybe someone can redesign those PCB, they are super simple, single layer, with kicad I guess half day max work but sorry I don’t have time myself to do it.
Thanks for HCFR, yes this is a good forum too
Alex.
It has to be a yes for a complete UGS-Muses (all boards) + UGS4 and/or the UGS4x + adapter board.
J109/k389 are just dual J74/K170. I believe the 2SK209GR (Idss; 2.6~6.5 mA) or 2SK209BL (Idss; 6.0~14 mA) is a good substitute. They are roughly €0,35/pcs if one order more than 10 pcs.
2sk209gr are available but what’s with the 2sk209bl?
would the gr type be „enough“?
Hello Alex
I am also a taker, below the updated list.
cordially
Updated:
Twitchie : 1-2 PCB sets + gain stage (if offered)
Guyisme : 3 MCU + L/R PCB
Gionag : 1 PCB set ?
Fencki : 1 PCB set + gain stage (if offered)
Mensing : 1 PCB set
Itsallinmyhead : 1 PCB set + gain stage (if offered)?
Kk74 : 1 PCB set
Fabian85 : 1 PCB set ?
Eriksson : 1 PCB set ?
Myl : 1 PCB set + 2 gain stages ( if offered )
Ernesternest : 1 PCB set
Norgaard : 1 PCB set + 2 gain stages ( if offered )
Dennis Hui : 1 PCB set
Astromo : 1 PCB set ?
Oneminde : 1 PCB set + gain stage (if offered)
Stanney2017 : 1 PCB set.
Stones : 1 PCB set
schultzsch : 1 PCB set
HelmutHolz: 1 PCB set + gain stage (if offered)
trung224: 1 PCB set
Awh: 1 pcb set
Adams_Leo: 1 PCB set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Emyeuoi : 1 PCB set + gain stage (if offered)
Briangasberg : 1 PCB set + gain stage (if offered)
Jacek_k_wawa : 1 PCB set + gain stage (if offered)
Naz : 1 PCB set
vannhoem: 1-2 PCB set +gain stage (if offered)
Hicoco 1 PCB set
unixdeveloper : 1 PCB set + gain stage (if offered)?
lancer: 1 PCB set + gain stage (if offered)
lapoulpe: 2 (PCB set + gain stage)
cordially
Updated:
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
Hello Alex
cordially
Updated:
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
cordially
Updated:
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
The adapter board comes via Ine and I guess its only fair that he has a say about that part. He did mention that he is working on a new version for the output capacitors - so unless he is against sharing the adapter board with the rest of us, things are looking kinda decent.
Yes, for sure I have a say about that ! My adapter board is not meant for the UGS 4. Oneminde have to send me a ready assembled UGS 4 module for testing first.
I would recommend to all new builders to go for the original UGS. We all know that module it is working quite well.
Updated:
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
redjr: 1 PCB set + gain stage (if offered)
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
Updated - the UGS4 is removed as an option for the time being.
Fencki : 1 PCB set
Mensing : 1 PCB set
Kk74 : 1 PCB set
Myl : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Emyeuoi : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
lancer: 1 PCB set
lapoulpe: 2 PCB set
redjr: 1 PCB set
Fencki : 1 PCB set
Mensing : 1 PCB set
Kk74 : 1 PCB set
Myl : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Emyeuoi : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
lancer: 1 PCB set
lapoulpe: 2 PCB set
redjr: 1 PCB set
BL grade is preferred.
one additional question:
will there be all the pcb‘s available in the kit? with all the small ones on the back too?
and ugs pcb‘s from the former GB? external PSU pcb‘s?
thx
Yes all the PCB included. Please look at HCFR thread to see the details. First page. In French but first page links are self explanatory.
Unfortunately not because the UGS3 used only implements 2SK389 / 2SJ109.
I see the BOM at <<UGS - Muse edition>> - 30058092 - sur le forum <<Amplis et Preamplis>> - 1056 - du site Homecinema-fr.com, 2SK389 / 2SJ109 can be replaced by sk170bl/sj74bl. Is it acceptable and any adjustment for that?
@ Ine: Sounds fair. Lets do that. We are back at the original UGS gain stage and we can look at a UGS4 situation further down the road and use this thread to inform about any progress.
Perfect because as I mentioned earlier I would prefer to have this separated from this PCB GB, to avoid such untested problems.
And also I know Eric well and trust very much his comments regarding the complexity to make a module with NFET only.
Probably but I won't do it. I let you redesign an UGS3 or 4 with the matched j74/k170.
Would 1206 (3216 metric) resistors work for everyone ? The reason I ask is that Panasonic Era resistors measure among the best and is a really good choice.
- UGS-muse preamp GB
