Thanks Patrick. I thought about using the Toshiba parts because I have them. However, I did secure a small stash of the 2SK209GR devices due to you highlighting them.UDNeSS is about using active devices. So no need to use 2SK170s.
2x 2SK209GR will replace 1x 2SK170BL adequately.
50W rms into 8R means +/-32V rails and 1.8A bias.
You will need a total of 4 matched MOSFETs, each dissipating 29W.
This is just simuilation.
So build at own risk.
Patrick
I will try and play with the sim.
Mogens
Do the upper and lower mosfets need to be matched together?UDNeSS is about using active devices. So no need to use 2SK170s.
Patrick
Or matching is needed only for the upper and lower pairs? Meaning 2 pairs and not a matched quartet?
Question on the OPA 604 opamp: it is still active, but not a single supplier has any stock, so it has basically become unobtainium. I checked the TI website, and they have many other audio opamps, but almost all of them can only have +/- 18 V supply. Would it be OK to feed them from a secondary supply with a L7818 3-point stabilizer connected to the 24 V rail? Would involve making a seperate PCB for the servo..
I bought this one recently https://www.ebay.com/itm/252046879741
From China, it works at 22.5 volts in my case.
Rush
Rush
There is no need to install servo by default.
You should build basic amp first, and loaded it with a dummy load.
Then you see how much drift you have on your case / heatsink.
If the drift is say < +/-100mV, I would not bother with servo.
More useful to install a speaker protection circuit.
For example that from Pavel :
https://www.diyaudio.com/community/threads/output-relays.191449/post-2835407
Patrick
Patrick
post 351 "There is no need to install servo by default.Are we talking about different things ?
Patrick
Then you see how much drift you have on your case / heatsink."
- UDNeSS, or You don't need Semisouth's
