UDNeSS, or You don't need Semisouth's
In this scheme is also Q1 - KSC1845.
KSC1845 is an active device with plenty of voltage headroom.
Very easy to get. So why replace ?
If I like to use 2SJ618 or 2SJ201 then what changes are needed in this scheme and in this following scheme?
They are both obsolete devices, so I shall not spend any time figuring out how to apply them here.
It is not what this circuit is meant for,
And I will certainly not publish any unproven schematics using them.
You are of course most welcome to run your own simulation using those devices.
In real life, you need to apply thermal compensation for the large positive tempco of the 2SJ618.
In addition, you need to change the values of the source resistors and the gate biasing resistor because of different Vgs ad Yfs.
Success,
Patrick
Active at Mouser / DK means that it is not obsolete.
Now clear ?
Again, UDNeSS was designed not to use ANY obsolete parts.
It does not matter what you can still get from ebay or diy store or what not.
Everything posted in this circuit, you can get from Mouser / DK with no NOS premium.
Patrick
Reactions: 1 users
