UCD 25 watts to 1200 watts using 2 mosfets
Thanks laci...
Can you suggest me level shifter values for high voltage operations? On example +-70V or higher... When level shifter transistor burns always explode transistor near by 120R..
I tryed with 2N5401, MPSA92 but I will try MJE350... I use 120R, 47K, 2x 2.2K like in original but always fail with +-70V on startup..
Can you suggest me good combination?
Can Somebody post real pcb layout of IRS3000D I was looking layout of irs2000 and I am confused with some resistors I dont see on the original IRS3000d design but see on this Layout?
my current project i decided to go non ucd way :D
  • gtG 800 schematic.pdf
  • gtG 800 components clear.pdf
  • gtG 800 components full.pdf
  • gtG 800 pcb artwork 2 smll.pdf
  • gtG 800 pcb artwork smll.pdf
Hi Stewin,
Sigma Delta design is good for all
NB: using BIAS +15V you should reduce the value R13 to @250KHz FSW range
MANOJ
thanks sir manoj originally i had planned to use irfb4227 or irfp4668 .but since i am using irfp250n i will change the swithching frequency.
also i wanted to reduce fsw by using 820ohms to about 200 khz so as to drive the amp harder :D :D:D.
. thanks again for the correction. i will post the smps i am developing :).
