UCD 25 watts to 1200 watts using 2 mosfets
norazmi,
if your up to DIYing the coil, you could also use an medium size E-E ferrite core(gap it at the center) say 1mm and wind your coil at the bobbin.. it helps to have an LC meter to measure inductance...
Yes i do that, im trying with EE and UU small and medium size, but from my ear why is iron material gives good on bass sound better than ferrite, or maybe i dont make correct winding on ferrite core, idk.. i just tried with gapped ferrite toroid too but its same as when use EE and UU core hmmm, any ideas? So far im using T106-26 toroid iron with 18 awg sounds good so far heat not too much can be touch even i`m playing loud at full volume with +- 50 vdc. No noise at all when using linear power supply, but be carefull when using offline smps u need to have good filter for it.
regards.
Azmi.
Bonjopur, I return to the topic I made progress. I simulated the LTC software schematics Attached Files IR2110_UCD.zip (421.1 KB
But that does not give me a correct answer!
my questions
someone does make this amplifier
which simulate the schematics on LTC.
Thank you for your cooperation.
Greetings
