norazmi,
if your up to DIYing the coil, you could also use an medium size E-E ferrite core(gap it at the center) say 1mm and wind your coil at the bobbin.. it helps to have an LC meter to measure inductance...
Yes i do that, im trying with EE and UU small and medium size, but from my ear why is iron material gives good on bass sound better than ferrite, or maybe i dont make correct winding on ferrite core, idk.. i just tried with gapped ferrite toroid too but its same as when use EE and UU core hmmm, any ideas? So far im using T106-26 toroid iron with 18 awg sounds good so far heat not too much can be touch even i`m playing loud at full volume with +- 50 vdc. No noise at all when using linear power supply, but be carefull when using offline smps u need to have good filter for it.
regards.
Azmi.
hi,
That is why an LC meter is needed to measure the inductance .
If you dont have a meter you can put a capacitor in series and apply a sine wave and see where it goes to a minumum.
Then yo ucan work out the inductance from:
L= 1/(4 * pi squared * c * f squared)
Bonjopur, I return to the topic I made progress. I simulated the LTC software schematics Attached Files IR2110_UCD.zip (421.1 KB
But that does not give me a correct answer!
my questions
someone does make this amplifier
which simulate the schematics on LTC.
Thank you for your cooperation.
Greetings
my questions
Greetings
hi quinquin07 i built the amp and it performs great http://www.diyaudio.com/forums/class-d/166214-ucd-25-watts-1200-watts-using-2-mosfets-11.html
Class D
Bonjour, je vous remercie pour votre réponse, mais je copie les schémas de simuler sur "LTspiceIV de la technologie linéaire, mais je ne peut pas tourner, est-il une erreur?
Je joins les fichiers.
Salutations.
View attachment Ampli classe D.zip
Salutations.
Hello, thank you for your reply, but I copy the patterns to simulate on "LTspiceIV of linear technology, but I can not rotate, is there a mistake?
I attach the files.
Greetings.
English please
dave
Class D
I attach the files.
Greetings.
I attach the files.
Greetings.
is there any DC at speaker output or is this problem solved ?
No DC, make the board carefully, its small board. Btw i solve my lc filter with ferrite toroid core with gapped. no noise no hot and big power, now i`m enjoy my stereo class D amp.
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
