R13 on which exact schm?
on the preamp board
Hello
I am gathering parts together question with a wirewound resistor work for R13
Because it looks like the Panasonic in 330R are not available any more.
Dave
I just bought some from digikey. 330R 3 watt. 59 cents each
Through Hole Resistors | Resistors | DigiKey
I searched both Mouser and Digikey and they didn't come up
Thanks for the link
Dave
Marra -
The specific ones in the photos were obtained at a local electronics surplus store, so I have no details.
Here are two choices that should work well -
This is a clip-on -- 6237BG Aavid Thermalloy | Mouser
This is a screw-on -- 577202B00000G Aavid Thermalloy | Mouser
I bought the screw on versions you recommended here, for both BA-3 pre and BA-3 Power amp. I note they are considerably smaller than the monsters you used, are they sufficient for both pre and power, or are yours just massive overkill?
Russellc
Thanks for the link
Dave
Its easy to go "search blind" on these parts! If just the right term isnt searched it turns up nothing. I went to panasonic, then resistors, through hole and finally, there were the little blue beauties!
- The BA-3 as preamp build guide
