BLACK IS BLACK
Just earning my keep.
If they're black they're graphite.
Ah, but are they graphite or nickel?
Phoo, graphite or nickel ? I just put them away again in their safe box so that they can sleep some more years. They were black, that's all I know. Never have done anything with them. There is only this schematic with the 6384 ( I have them as well ) that keeps coming to mind. The Guided Missile Amp it is called.
I have the chassis but with tube amps I am just a lazy guy.
Never liked the hardwiring and the chassis-drilling etc.
TAKE THIS.
The material used for the anodes does not negate the necessity for a getter.
The main function of the getter is to burn any remaining gaseous content inside the valve.
At least in my book...
Not in my book Frank.
Extract:
http://www.fnrf.science.cmu.ac.th/theory/klystron/How%20A%20Vacuum%20Tube%20Works.html
And, the hot graphite plate will tend to react with, and absorb, any free oxygen in the tube. The Svetlana SV572 series and 572B use graphite plates coated with purified titanium, a combination which gives excellent gettering action. A graphite plate is much more expensive to make than a metal plate of the same size, so it is only used when maximum power capability is needed.
METALLURGY.
Ha,
Yes.
And it isn't the same thing.
On older noval tubes (small signal) you'll find quite a number with graphite plates + a getter.
And...they sound better!
Ha,
Yes.
GETTER THE GET...
Absolutely....I'll tell you more than that...
A tube with too high a vacuum would have a very short lifetime.
Funny huh?
Could it be that there are other gasses besides oxygen in the tube, John ?
Funny huh?
Jean-Paul,
Actually, I once heard that barium getters were only effective against oxygen.
I don't know if that's true, but many externally gassed tubes do glow blue at first.
Frank,
What is the 2nd function of the getter that you were intimating?
What I've been getting at is WHY, if you can make an effective graphite getter, would you go to the expense of a baruim getter as well?
Frank,
I know, I used to re-gun CRT'sA tube with too high a vacuum would have a very short lifetime.
Surprised?
Re: FALSE MODESTY?
Most of the SE Pentode EL84 amps i have (that indicate the primary impedance -- all German) have 7-10k primaries.
I plan on using a 6N1P (a buck each from Gintaris) as a starter driver tube when i get around to building a from the ground up SE EL84.
I used my SEP EL84 dumpster amp (4W) for some time on my 91 dB/1W speakers. It was mostly fine, but was definetly straining when i wanted to push the volume (my room is 24'x36'x10' ceilings (ave).
dave
fdegrove said:For penthode mode that is the Z to go.
dave
I've noticed that dave. Most of the american designs I've looked at use a 5K primary and the european designs used the higher 7- 8K
primaries. I wonder where the sweet spot is. By that I mean the best trade off between damping and power transfer. BTW that is a large room to try to fill with sound with a 4 watt amp driving 91dB speakers. I'll bet the little guy was sweating.
I'll change the caps to .1 uF Joel. Thanks. Do you think that the 5687 will do the job? I only need a gain of about 5 or so.
G
G
GETTERS.
Other than the usual tube manuals,this is a nice read:
Svetlana doc.
So other than burning off gaseous content the getter has a very important function:
It keeps the vacuum at the correct level.
There is more to say about this but I'll stop barking for today.
Svetlana doc.
G said:Do you think that the 5687 will do the job? I only need a gain of about 5 or so.
You will need more than that for most of the cd's I've ever run across. Yes, test CD's, etc, will put out 2V RMS, but that is unusual for a commercial music CD. I get arguments about this all the time from various forum people, but it's a very simple task to play some CD's and measure the output! I have done that.
Figure on needing a gain of 15 or more, to be safe.
Splitting hairs..
Well Frank, one follows from the other. In that case the getter also stops the heater from burning out Etc
I can't remember what vacuum we used to pump them to, but metal gas emission was a serious problem - so much so that it was necessary to ramp up the filament voltage as the vacuum got harder, to warm the gun. That was in addition to taking the whole assembly to a high temperature in an oven.
The best part was firing the getter with the RF heater
No graphite in CRT guns Maybe that's why they don't sound so good.
Yes, 2V is peak level.2V RMS, but that is unusual for a commercial music CD
Operating level is -12dB to - 14dB relative to 2V.
20log v1/v2 and all that
G said:I've noticed that dave. Most of the american designs I've looked at use a 5K primary and the european designs used the higher 7- 8K primaries.
Most of them are fairly modest in size, but i have one set from an East German hifi that are larger than the Dyna Mk III OPTs i have.
That would be a good description. It was a little less strained when i was running the sub with the extra 2x70 of sand power. My speakers are bipoles so i'm going to double my power by using 4 amps (and eventually more efficient speakers).
dave
5 Watts?
Hi G,
Did you ever determine if/how the el 84 yields 5w like the Zen Decware?
Also, if I understand the data sheets for this tube, the screen is to be connected to the plate to config as triode (the suppressor is internally tied to the cathode). However, the literature on pentodes suggest exactly this same configuration--so, how is this reconciled? That is, data sheet says screen tied to plate, suppressor tied to cathode = triode mode. Literature says the same config but it is in pentode mode.
Can you help me understand this?
Thank you,
Rick
Hi G,
Thank you,
Rick
- Tubes / Valves
- Tentative EL84 SE Design.
