TDA1541 info
Oups, I forgot the attachment :cannotbe:
Has anyone read the papers on the attachment?
Did RUDY J. VAN DE PLASSCHE work on the tda1541 ?
I compared the datasheets of the tda1541a, and tda1543 to try and see what the main differences were.
From this thread:-
-5 to -15V powers oscilator, and DEM circuits. (on the tda1541a datasheet they are decoupled to each other to ground)
I'm sure I would not understand the papers but i'm sure someone out there could translate!
Then maybe DEM reclocking could be worked on http://www.diyaudio.com/forums/showthread.php?s=&threadid=11949&highlight=
Kind regards,
Ashley.
hi,tubee
I didn't try the voltage-level circuit for 1541's I2S,because it is too complicated to me.
but I and my friends tried to add 3 resistors in the I2S which between CS8412 and TDA1541 for reducing the groud-bound effect,and got the much better sound.the best value of 3 resistors is 1K-3K(!) showed below,not 22-100 ohms which is ordinary in the other DAC.
