Polycarbonate is after PIO one of the best plastic caps. But indeed in my 304 i have MKP motor starter caps, quite good.
What is your suggestion as IV/buffer SeraTico?
I have a simple tube stage in mind, with a switching PS from an old pc or so.
Guido: a friend has an 880 with paper SM. Will copy all. But it is allmost the same around dac as my CD640.
Pro of 880: selected dac, epoxy pcb.
cons of 880: NO pcb gnd shield!!!
I moded once CD880
not much,
NOS mode (override 7220...)
recloced I2S,
discreet IV
that was all
it was really good.
I can imagine with clock generator changed to better one...
But I had some problems about mute at first.
There was clicking between songs.
So I somehow trace the signal (wo manual...)
from some controler chip and it was worked out.
not much,
recloced I2S,
discreet IV
that was all
it was really good.
I just changed mine to 220nF PPS, which has made a nice difference, but the most profound change was adding a low-noise reg to the SAA7220 filter.
Hi Lee,
What sort of low noise reg did you add to the SAA7220? Where dd you ground it?
Joe
printing from a pdf is easier..... (HINT ).
there's an e-mail button.
Ach ja natuurlijk Dank je Guido
Ondertussen ook wat gevonden:
http://www.megafileupload.com/en/file/27040/Philips-cd880-pdf.html
(wat lage resolutie)
jnewbold said:
Hi Lee,
Joe
Hi Joe, it is something pretty similar to the Sulzer regulator. I won't go into too much detail as we're getting a little o/t.
The 1541 is in my Marantz cd94 btw. I know I can change the chip to a 1541a, but is the 7220b the same pinout as the "A" version? Would I get improvements from changing that too?
Cheers, Lee.
Hi Lee,
Thanks. I'm on a bit of a budget so I'm preparing to try one of those "Rayregulators" with LEDs and "gyrator" from the Marantz CD63/67 megathread.
Don't know about the a or b rating for 7220. My Rotel RCD965X has b version.
I'm considering changing from SAA7232 bitstream DAC to TDA141. All the power supply are already in the CPD so a small(ish) pcb for 1541 and new output stage is all that is required, I think.
Joe
Polycarbonate caps do a good job curing digititis.tubee said:Polycarbonate is after PIO one of the best plastic caps. But indeed in my 304 i have MKP motor starter caps, quite good.
As for the IV I am using the same opamps as in the PrimaLuna Eight IV-upgrade board.
Sorry this was not funny of me.
I am using the OP275 as IV-converter and some analog filtering as in the Zanden patent # US6721427.
Note that newer made OP275s sound a bit more bright than older ones.
I for one do not see any need for 100V/us slew rate opamps as in the PrimaLuna upgrade board. NON-OS would relax this spec anyway.
- Digital Line Level
- TDA1541 info
