More TDA1545A porn...
Someone really went to town with diyparadise TDA1545A kit ...
Again, the point being ... yeah ... duh .... OF COURSE it'll sound good with ALL THAT time/effort/$$ "invested" (although some of would call it wasted).
The TDA1545A /1387 is putatively avail. in SOIC (SO8) and can run on very low power. So, folks, something like ...
Put it up on kickstarter and, then, Tindie ... make a YouTube "unboxing" video ... create that dedicated Facebook or Blogger page ... and Twitter the hell outta it ... oh and, uh, those ubiquitous FANBOY "appreciation" threads on on pre-pubescent headphone-gear communities help, too
A dedicated "crowd-source" or "development" thread on DIY or audio-enthusiast sites means you don't really have to do a lotta brainwork ... let the "crowd" do it ...the loot from kickstarter is all yours no matter what ... Chinese factory will mass-produce your "crowd" project for peanuts.
No, ain't all that funner than plain-jane DIY?
I've never tried using a transformer without a filter first so I can't even have a stab at answering your question. I know some designs have used this kind of scheme, I gather they intend to use the trafo not only for isolation but also filtering. The problem with that approach is that the filtering is a side-effect, meaning its very sensitive to small details about the trafo's construction. So the SQ will be really hit-and-miss.
I recommend filtering first - then the trafo's job is much easier and you can wind it yourself, saving a whole heap of cash
<edit> If you want to buy a commercial trafo to try this ISTM that the critical parameter is going to be the primary inductance. Without enough inductance the trafo will have an LF roll-off determined by the source impedance driving it (which is the I/V resistor). Trafo's generally don't perform well when driven from a non-zero source impedance, so this is the aspect to watch. In my design I buffer first before the trafo so the trafo's inductance doesn't matter so much, also I believe this gives lower distortion.
A simple example - if your I/V resistor is 1kohm and the trafo's primary inductance is 10H this forms an LR high pass filter which is -3dB at 16Hz. Meaning significant bass roll-off. Ideally for the bass response you'd want an I/V resistor (in ohms) less than 30X the primary inductance (in Henries). This is a reasonable rule of thumb for keeping the bass droop under control. Probably though you'll get considerable LF distortion with this much driving impedance.
Yep - it's item 390922499784 on fleabay.
That board's using the WM8804 S/PDIF receiver and that IC can certainly output I2S. However it might be a bit fiddly to reconfigure it as the WM8804's package is very small (0.65mm pin spacings). Page 19 of the DS shows which pins control the interface format.
Before modifying for the TDA1387 I thought I'd have a good listen in its stock form (WM8804->TDA1545) so I put together a simple DC PSU and it does sound great. Very clean treble as a few have already mentioned. One thing I find odd is that the iv resistors are 4k7, if my reading of the datasheet is correct, this is too high??
Indeed. Clearly it's been maximised for a larger vrms I think. For pin 7 IREF the voltage is 0.83V, which looks correct as per datasheet. Interestingly they've installed a trimpot to adjust this if necessary.
What about reducing the iv resistor right down and using a trafo for gain?
I have some of these laying around.
Would they do the trick for some additional gain?
The output impedance scales as the voltage ratio squared. So for 5.5X that's 30X. So with a 470R you'll be looking at 14k. A bit high.
The solution I'd use is to stack DAC chips to increase the output current. With the TDA1545A you can tweak up the pin7 voltage a bit, but I found problems going over 1.2V.
Ok so there's a few possible mods. I can even just insert an additonal gain stage (non trafo) in between the dac and the power amp (I have a very linear premium that doesn't colour the sound much).
Really I just want to optimise the TDA1545 so it's operating the best possible conditions prior to stacking a few on top, then trying out the TDA1387 etc.
In short - Abrax, if you had this board, (a) what would you change the iv resistor to, and (b) would you tweak up the pin7 voltage or leave it as 0.83?
If I were playing with this I'd choose an I/V resistor to suit one of my filters. I think I have a filter with 2k5 input impedance. so it presents 1.25k to the DAC. Seems worth tweaking up the Vref a little to get the maximum output from the filter, paying attention to the excursions on the outputs not exceeding the compliance voltage spec.
Beyond that, the listening satisfaction is improved immensely with a very low impedance power supply at LF (paralleled supercaps work a treat), plus a whole heap of caps (at least 20,000uF) decoupling Vref.
I've been in touch with TekDevice recently about their TDA1387 module and they have a new one in development, due out in a few weeks. It will be a module with four TDA1387 on board. I'll post more when I've got my board....
did you mean this one
TDA1387 I2S DAC Module Passive Resistor I/V
did you already try it ?
- Digital Line Level
- TDA1387 continuous calibration dac
