IChi do you know your Beaglebone Black's hardware revision?
PCB REV6 on bottom of board under power connector, is that it?
This is a new in box BBB-C from Adafruit. Recieved last week.
https://rcn-ee.com/rootfs/bb.org/re...bian-7.8-lxde-4gb-armhf-2015-03-01-4gb.img.xz
This is the image you need to get
Always format SD card before you write an image on it.
Do not use Winrar to unzip the image , the file you get from Winrar is not a disc image.
Get windows image writer application and write the above image file to it.
Completely disconnect BBB board from USB and power supply and insert SD card with image into slot.
Hold down the boot button ( not power or reset) and plugin the 5v power cable .
The LED will blink and then started moving from side to side like a wave then release the boot button.
Wait for 30-40 min until all lights are light up and then machine power off by itself.
Take out the SD card and power on again. You are all set.��
I had this version, but the site address was a little different. File sizes are the same. It did load but the root logon required a password. The version you point to that I loaded does not require a password. Good. I'm a little worried tho, the flashing only took a little more than 5 minutes!? Seems ok. Took your advice and didn't use WinRAR to unpack, used 7-Zip. I've always used "Win32DiskImager-0.9.5-install" and "SDFormatter".
Now, to try Botic. It's late now so, first thing tomorrow!
Thank you very much, don't know why the seemingly same version I down loaded didn't work. But could have been the WinRAR unpacker!
it is the winrar ,If you look at the file it creates it will be folder and not an actual image file. With folder structure you can not boot from any media.
dont worry about time it took to flash the eMMC. As long as you have seen the pattern of lights and at the end al lights off by itself you are good.
Can some one post a detailed instruction on how to manually edit mpd.conf
or a link to how to do it?
The easiest alternative option:
1. download file from BBB to your computer (e.g. using WinSCP from Windows)
2. edit file at your computer with editor that does not damage lines in the file (e.g. PSpad)
3. upload edited file back to BBB at same place (works with WinSCP too)
I used Mieros instructions to flash Botic, but after that when I logon as root
it doesn't take botic as the password? - ssh root@IP_ADDRESS (password is botic)
Also, using - diyAudio server HTTPS page (MPD web interface) only takes me to a page that has ....
Index of /
NameLast modifiedSizeDescription Apache/2.2.22 (Debian) Server at 192.168.7.2 Port 8080....can't really say I've got Botic on the BBB!?
root@volumio:/# onfiguration file `/etc/upmpdcli.conf'
> ==> Modified (by you or by a script) since installation.
> ==> Package distributor has shipped an updated version.
> What would you like to do about it ? Your options are:
> Y or I : install the package maintainer's version
> N or O : keep your currently-installed version
> D : show the differences between the versions
> Z : start a shell to examine the situation
> The default action is to keep your current version.
> *** upmpdcli.conf (Y/I/N/O/D/Z) [default=N] ? ^C
> root@volumio:/#
what should be the answer to this?
> root@volumio:/#
password is volumio if you are installing over volumio
Is this meant for me?
Installing over volumio?
Boy, I'm in over my head!
Setting up a music server with Cinnamon Mint was a walk in the park.
Hi!
Been following this thread for a long time now and want to thank everyone who has contributed so far!
I wonder if anyone has tried to program i2c control of the ES9018 with BBB and Botic yet? I feel like that is the last thing that is missing now to get the ultimate embedded system I have tried to look in to it myself, but the programming that is needed is too complicated for me to handle. Any help or advice would be much appreciated!
I'm trying to build a squeezelie in the Botic distro/environment:
Unfortunately I recive masage:
Then I installed alsa but it didn't help at all.
See details:
Please give me a hint.
Thanks in advance.
Code:
fatal error: alsa/asoundlib.h: No such file or directory
See details:
Code:
root@botic:/opt/squeezelite# uname -a
Linux botic 3.18.7-botic4 #1 PREEMPT Wed Feb 18 23:34:58 CET 2015 armv7l GNU/Linux
root@botic:/opt/squeezelite# OPTS="-DFFMPEG -DRESAMPLE -DDSD" make
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD main.c -c -o main.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD slimproto.c -c -o slimproto.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD buffer.c -c -o buffer.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD stream.c -c -o stream.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD utils.c -c -o utils.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output.c -c -o output.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output_alsa.c -c -o output_alsa.o
output_alsa.c:27:28: fatal error: alsa/asoundlib.h: No such file or directory
compilation terminated.
make: *** [output_alsa.o] Error 1
root@botic:/opt/squeezelite# apt-get install alsa
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'alsa-base' instead of 'alsa'
Suggested packages:
alsa-oss oss-compat
The following NEW packages will be installed:
alsa-base
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 61.1 kB of archives.
After this operation, 134 kB of additional disk space will be used.
Get:1 http://ftp.us.debian.org/debian/ wheezy/main alsa-base all 1.0.25+3~deb7u1 [61.1 kB]
Fetched 61.1 kB in 0s (107 kB/s)
Selecting previously unselected package alsa-base.
(Reading database ... 24393 files and directories currently installed.)
Unpacking alsa-base (from .../alsa-base_1.0.25+3~deb7u1_all.deb) ...
Setting up alsa-base (1.0.25+3~deb7u1) ...
Thanks in advance.
You'll need to install ALSA development packages.Hi,
Then I installed alsa but it didn't help at all.Code:fatal error: alsa/asoundlib.h: No such file or directory
See details:
Please give me a hint.Code:root@botic:/opt/squeezelite# uname -a Linux botic 3.18.7-botic4 #1 PREEMPT Wed Feb 18 23:34:58 CET 2015 armv7l GNU/Linux root@botic:/opt/squeezelite# OPTS="-DFFMPEG -DRESAMPLE -DDSD" make cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD main.c -c -o main.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD slimproto.c -c -o slimproto.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD buffer.c -c -o buffer.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD stream.c -c -o stream.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD utils.c -c -o utils.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output.c -c -o output.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output_alsa.c -c -o output_alsa.o output_alsa.c:27:28: fatal error: alsa/asoundlib.h: No such file or directory compilation terminated. make: *** [output_alsa.o] Error 1 root@botic:/opt/squeezelite# apt-get install alsa Reading package lists... Done Building dependency tree Reading state information... Done Note, selecting 'alsa-base' instead of 'alsa' Suggested packages: alsa-oss oss-compat The following NEW packages will be installed: alsa-base 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 61.1 kB of archives. After this operation, 134 kB of additional disk space will be used. Get:1 http://ftp.us.debian.org/debian/ wheezy/main alsa-base all 1.0.25+3~deb7u1 [61.1 kB] Fetched 61.1 kB in 0s (107 kB/s) Selecting previously unselected package alsa-base. (Reading database ... 24393 files and directories currently installed.) Unpacking alsa-base (from .../alsa-base_1.0.25+3~deb7u1_all.deb) ... Setting up alsa-base (1.0.25+3~deb7u1) ... root@botic:/opt/squeezelite# OPTS="-DFFMPEG -DRESAMPLE -DDSD" make cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output_alsa.c -c -o output_alsa.o output_alsa.c:27:28: fatal error: alsa/asoundlib.h: No such file or directory compilation terminated. make: *** [output_alsa.o] Error 1
Thanks in advance.
Code:
sudo apt-get install libasound2-dev
Code:sudo apt-get install libasound2-dev
Thanks,
There are other obstacles...
Because I have fatal error with ffmpeg:
Code:
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output_pa.c -c -o output_pa.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output_stdout.c -c -o output_stdout.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output_pack.c -c -o output_pack.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD decode.c -c -o decode.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD pcm.c -c -o pcm.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD mad.c -c -o mad.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD vorbis.c -c -o vorbis.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD faad.c -c -o faad.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD mpg.c -c -o mpg.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD dsd.c -c -o dsd.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD dop.c -c -o dop.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD dsd2pcm/dsd2pcm.c -c -o dsd2pcm/dsd2pcm.o
cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD ffmpeg.c -c -o ffmpeg.o
ffmpeg.c:25:34: fatal error: libavformat/avformat.h: No such file or directory
make: *** [ffmpeg.o] Error 1
root@botic:/opt/squeezelite# libavformat/avformat.h
Code:
root@botic:/opt/squeezelite# apt-get install libffmpeg
E: Unable to locate package libffmpeg
Have you tried searching?Thanks,
Despite I've installed libffmpeg, receive:
Code:root@botic:/opt/squeezelite# OPTS="-DFFMPEG -DRESAMPLE -DDSD" make cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD main.c -c -o main.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD slimproto.c -c -o slimproto.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD buffer.c -c -o buffer.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD stream.c -c -o stream.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD utils.c -c -o utils.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output.c -c -o output.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output_alsa.c -c -o output_alsa.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output_pa.c -c -o output_pa.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output_stdout.c -c -o output_stdout.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD output_pack.c -c -o output_pack.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD decode.c -c -o decode.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD pcm.c -c -o pcm.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD mad.c -c -o mad.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD vorbis.c -c -o vorbis.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD faad.c -c -o faad.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD mpg.c -c -o mpg.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD dsd.c -c -o dsd.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD dop.c -c -o dop.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD dsd2pcm/dsd2pcm.c -c -o dsd2pcm/dsd2pcm.o cc -Wall -fPIC -O2 -DFFMPEG -DRESAMPLE -DDSD ffmpeg.c -c -o ffmpeg.o ffmpeg.c:25:34: fatal error: libavformat/avformat.h: No such file or directory compilation terminated. make: *** [ffmpeg.o] Error 1 root@botic:/opt/squeezelite# libavformat/avformat.h
Code:
pi@raspberrypi ~ $ sudo apt-cache search libavformat|grep -i dev
libavformat-dev - Development files for libavformat
Success
I've just build squeezelite player!
After installing libavformat53, libavformat-dev, libavcodec53 and compiling libsoxr the output devices are as follows:
Code:
root@botic:/opt/squeezelite# ./squeezelite -l
Output devices:
null - Discard all samples (playback) or generate zero samples (capture)
default:CARD=Botic - Botic, - Default Audio Device
sysdefault:CARD=Botic - Botic, - Default Audio Device
dmix:CARD=Botic,DEV=0 - Botic, - Direct sample mixing device
dsnoop:CARD=Botic,DEV=0 - Botic, - Direct sample snooping device
hw:CARD=Botic,DEV=0 - Botic, - Direct hardware device without any conversions
plughw:CARD=Botic,DEV=0 - Botic, - Hardware device with all software conversions
follow_outside_symlinks "yes"
follow_inside_symlinks "yes"
db_file "/var/lib/mpd/tag_cache"
sticker_file "/var/lib/mpd/sticker.sql"
log_file "/var/log/mpd/mpd.log"
pid_file "/var/run/mpd/pid"
music_directory "/var/lib/mpd/music"
playlist_directory "/var/lib/mpd/playlists"
state_file "/var/lib/mpd/state"
user "mpd"
bind_to_address "any"
port "6600"
zeroconf_enabled "yes"
zeroconf_name "volumio"
samplerate_converter "Best Sinc Interpolator"
volume_normalization "no"
audio_buffer_size "2048"
buffer_before_play "20%"
filesystem_charset "UTF-8"
id3v1_encoding "UTF-8"
gapless_mp3_playback "yes"
auto_update "no"
mixer_type "disabled"
group "audio"
max_connections "20"
decoder {
plugin "ffmpeg"
enabled "yes"
input {
plugin "curl"
audio_output {
type "alsa"
name "Output"
device "hw:1,0"
dop "no"
user "mpd"
port "6600"
auto_update "no"
group "audio"
decoder {
plugin "ffmpeg"
enabled "yes"
input {
plugin "curl"
audio_output {
type "alsa"
name "Output"
device "hw:1,0"
dop "no"
FOLLOWED THE INSTRUCTIONS HERE
https://docs.google.com/document/d/...OSF2fu3Sz4zzmaURM/edit#heading=h.pb0sutxuyej0
still not able to acess USB DRIVE
user "mpd"
port "6600"
auto_update "no"
group "audio"
decoder {
plugin "ffmpeg"
enabled "yes"
input {
plugin "curl"
audio_output {
type "alsa"
name "Output"
device "hw:1,0"
dop "no"
user "mpd"
port "6600"
auto_update "no"
group "audio"
decoder {
plugin "ffmpeg"
enabled "yes"
input {
plugin "curl"
audio_output {
type "alsa"
name "Output"
device "hw:1,0"
dop "no"
IMHO, you are still trying to edit the default mpd.conf provided by Volumio, which is of no use with boticized Volumio. Read again miero's comments so far with full effort. BTW, this boticized Volumio is intended for I2S connection; not for your USB DAC.
Correct me someone, if I'm wrong.
- More Vendors...
- Twisted Pear
- Support for Botic Linux driver
