Studio Reference Amplifier
Ex-Moderator R.I.P.
Joined 2005
Thimios, if the resistor is soldered with its leads mostly clipped off, then it should have minimal series inductance. That is one example. With your resistor being the core material of the inductor, I don't know how this affects inductor behavior for better or worse. I wouldn't expect a film resistor to do much unless it stuck to a magnet, but I really don't know anything about magnetics.
My response was to the post I quoted, where the resistor leads were left long and soldered at the ends. This would be okay, if the connections to the L/R were right across the resistor rather then inches apart.
Thi,
you need to sort the LTP balance first.
Change the Tail current until the Vdrop on the LTP emitters is identical.
Then remeasure the R27 & 28 voltages/currents.
Also check the output offset.
Hi Adrew
output offset is zero.(servo presence)
''Change the Tail current until the Vdrop on the LTP emitters is identical.''
probably you mean closer matched transistors.
It's in my mind to do this.
It is just a prototype for functionality check.
In any cases this is the proof that it is not enough matching hfe
Thanks for your interest
Best regards
