Small full range
ok:
the Funtek fe85 cost 16€
the TC9FD18-08 cost 19€
the Funtek fr88 cost 36€
the Visaton B80 cost 50€
the scanspeak 10F/8414G10 cost 60€
the Markaudio 6m cost 70€
I have to build 10 speakers the cost it could be not a problem but if there are no big difference i do not like spoend three times
what speaker do you sugget?
other question
do you think that it could be possibile find a driver like 130mm that could work with a small volume?
thanks as always
Matt,
Your link is to a webpage, not a picture so it is not showing up.
4L for the P7 is a little less than optimum but still fine. I’d guess an F10 of near 60 Hz with a small bump before it starts rolling off.
See attached. Do note that these sims are without damping. Damping can increase the apparent volume up to about 20%.
dave
Thanks dave, I think technically it is 4.3L, and I plan to add a little dampening too.
here's the design.....
http://kjfaudio.com/wp-content/uploads/2016/11/Pv7-sealed0point15ft_3.pdf
not sure how to add pictures on here properly, I have to add linkls to my onedrive which is shared, but they never show up as thumbnails, as some do on here? any idea why?
Think I've sussed it.....
  • Pv7-sealed0point15ft_3.pdf
