The cheapo champion, the 9FD, will reach down to 80hz, or even 50hz, but it needs quite a box. Perhaps 10L ported. Sealed in 3-5L, 100hz is about it. The 10F/8424 is happier in a smaller box and gives similar results.
There is quite a lot about the 10f here 10F/8424 & RS225-8 FAST Ref Monitor
several separate questions to unpack in the first sentence alone, but my own take on the subject would be
1) Yes, I can thing of several "full-range" drivers capable of 80Hz - although not necessarily in a sealed box of reasonable size; What exactly is the problem with vented in your application?
2) On/in wall mounting will certainly reduce if not completely eliminate baffle step loss - whether using a single or multiple full-range drivers or multi-ways, so getting to or below the cut-off frequency for your LFE channel shouldn't be an issue. .
3) By "flat" do yo mean literally flush to the wall - ie. in-wall mounted? The issue there is that with most modern construction standards, there will be very shallow net cavity depth, which can cause coloration issues with lighter coned full range drives, and wall stud locations may interfere with preferred speaker placement .
Multi-channel home theatre was complicated enough before this crazy Atmos thing - past the point of 5.1, I think you really need to be able to be in a position to spend the money and time/space to dedicate the room to the purpose.
One other question
Do you thinks that there is a full range able to go down on a ��80Hz in the way that I can use on a wall and it is has to be flat?
XRK built some wall mounted speakers that looked pretty good. Try a google search VIFAntastich for some ideas
Thanks for the answer
I am looking for something that it could be match with my front
Actually I have Sonus Faber Venere 3.0 and venere center like a center
I will use a double diy sub Dayton Audio ultimax 15
And I am looking for 8 speaker like surround and Atmos that could be a good matching
Now I am open to suggest
I need something that it will be tiny
I was looking for the indian line tesi q but then I start to tink that maybe i could spend the same money for a better quality in the diy
make something vented it will not a problem but we have to remember that I will use that with 100wat and that it will attach at the wall and at the calling not inside
Do you have suggest for some project?
This is esactlay what I am looking for but I wan to have a more good speaker I can reach 50€ for every one or at lost 100€ if the quality it will be amazing
I am little bit afraid the the small visa it will be not enough in my HT
I do not have problem if it will be a full range or a two way this my budget
Andrea
- Full Range
- Small full range
