ok:
the Funtek fe85 cost 16€
the TC9FD18-08 cost 19€
the Funtek fr88 cost 36€
the Visaton B80 cost 50€
the scanspeak 10F/8414G10 cost 60€
the Markaudio 6m cost 70€
I have to build 10 speakers the cost it could be not a problem but if there are no big difference i do not like spoend three times
what speaker do you sugget?
other question
do you think that it could be possibile find a driver like 130mm that could work with a small volume?
thanks as always
other question
thanks as always
Matt,
Your link is to a webpage, not a picture so it is not showing up.
4L for the P7 is a little less than optimum but still fine. I’d guess an F10 of near 60 Hz with a small bump before it starts rolling off.
See attached. Do note that these sims are without damping. Damping can increase the apparent volume up to about 20%.
dave
Thanks dave, I think technically it is 4.3L, and I plan to add a little dampening too.
here's the design.....
http://kjfaudio.com/wp-content/uploads/2016/11/Pv7-sealed0point15ft_3.pdf
not sure how to add pictures on here properly, I have to add linkls to my onedrive which is shared, but they never show up as thumbnails, as some do on here? any idea why?
dayton audio rs100 8 cost 39€
this is the link of my options
All woofers - SoundImports.eu | Dayton Audio, miniDSP and Sure Electronics
thanks so much
thanks so much
one other important info is that at the end of that 10 speakers i would love to build a three big speaker for the front and the center
i love to make something like that:
cabasse io2 stands - Google Search
budget 1000-1500€
thanks
budget 1000-1500€
thanks
Well....with DIY you can make whatever you will/want !
Problem with audio is... the final product sounds good ?
I saw the minionken
They are to depth 30 cm......no way
I need something like 10cm max less it is could be better
Essenziale I want something with the depth of the ap
budget 1000-1500€
thanks
Search for the Ikea bowl thread...many examples along the way
This is it exactly my question and why I am asking your help
I think this is why it is maybe a good idea to try someone else’s design as a first project. That’s why I decided to take this route.
is it ok for the fountek fe85?
I've no idea, but I doubt it. This design is based on the Mark Audio Pluvia 7 driver.
Pluvia 7 – Soft Chrome/Vintage Gold (pair) | KJF Audio
Jus one information
I saw that the Fountek 85cost 16€ and the pluvia 7 it cost 60€ there is a real reason like so much better or only different taste?
- Full Range
- Small full range
