Slewmaster - CFA vs. VFA "Rumble"
In what way does it sound better?
-RM
Clearer, better resolution especially in the treble, things sound 'finer' if that makes sense:rolleyes: Sounds seem to fade away more and stop more precisely than before.
I am not one for subjective mumbo jumbo and I'd like to know what to attribute to this difference in perceived sound quality. I mean this amplifier has a completely different compensation scheme, fully regulated input stage, is a CFA vs VFA, is probably faster than the previous design, has a symmetrical input stage, has RC filtering in a number of places and has two pairs of output transistors per channel rather than just one pair. These are driving benign 4 ohm loads and going to two pairs does reduces large signal non linearity. I mean the amplifiers are technically superior in a number of ways, so there are good reasons for it to sound better.
I need to get my second PSU completed so I can do a solid all Slewmaster A/B comp setup. I have 4, 5 pair OPS mounted on two huge heatsinks and two identical 55-0-55vac transformers. I only have one filter bank for it. Now that I have a break from building IPS boards I should concentrate on getting another filter bank built. Then my dual test setup can be completed. Hopefully just in time for OS's return. He claims he has a bunch of new IPS designs. :lickface:
Another pic of my build
Tested with diy SMPS halfbridge +-75vdc and pushpull +-60vdc
Got a Symasui board stuffed today for QC check. Looks good so far, just need to get an appropriate op-amp for the servo tomorrow.
Hi Jason,
My boards should arrive today. I have a question about the 2.2u caps C1 and C13. Can those be electro and if so, which way should the polarity face?
Thanks, Terry
It is not simpler (better) to ommit whole servo circuit and instead this put simple capacity (electrolytics, AC voltage across cap few mV, no distortion) about 220uF in series with R25? You get 100% DC NFB, and output ofset will be in mV region (caused only by h21 unbalace Q1,Q2,), no servo needed. Now is here DC bias resistor unbalance R25//R24 vs R2, and resulting input ofset voltage is amplified by amp gain, than corrected by servo..A bit strange and complicated.
