Simple Symetrical Amplifier
I think the basic topology is tremendous. You have attacked the output in a unique manner..where you aim to remove the P to N differences. I have fitted a current dumping error correction circuit on the version I have built. which by the way sounds rather ok...
Now to the house keeping. I do believe that the weakest part of this fine circuit and the very reason why it does not simulate particularly well is the poor relations between the impedance of the current drive and the feedback currents. The basic amp is basically fed from a 1Kohm current source..which is way too low to prevent the feedback currents from modulating the drive-current. This is the main source of error in the circuit and by fitting high (very high) impedance current-sources specs are terrific. I will not show my housekeeping here....But I'am quite sure you catch the direction.
By the way. Good you replaced the zeners by LM431!!! The Zeners mess things up!
Yeah, I knew that from begining, TL431 makes much more stable current supply to the bridge, unaffecting the fixed cascodes base potential, still current sources puts relations to another level. OK, tracking cascodes at input and VAS again another story, so all together combined I'm not surprised it is tremendous. :cool:
Sound? :rolleyes:
Just to show the difference.
Sims are very useful tool to avoid-eliminate major flaws and helps converging to the best solution by optimizing/correcting the parameters. Still the basic ideas of topology and solution is up to a designer. In reality all well designed circuits has to be tested throughout especially on stability issues, since these are parts-layout dependable. And if you go to tracking cascodes, current sources ie. high impedance local circuits in a big scale, where oscillations and instability are just around the corner, than a designer must really have a good knowledge and a lot of practical experiences. :)
But i would allways add a little series resistor to prevent oscillations in real world, also on mosfets.
Sometimes practical results (measurements & sound) are better without them. ;)
Spectral analyzer shows incredibly linear and even response in spectral distribution up to 100 MHz region. Increasing the amplitude of the base signal enlarge the amplitude of all spectral lines in a linear manner, there's no step amplitude response between first few and damping of the others, like it should be. So the 1 k resistor is doing it properly, allowing the drive-supply current (which by definition should be constant) to be modulated by FB current in a very frequency-linear manner. So nothing to blame to resistor, it's doing its job just perfectly. :D
Achieving high impedance current supply by cascoded CCS is not a problem, we also had CCS in the SSA sch long time ago although more or less because of their constant part of equation. OK, I have 14 V potential gap, very constant and clear TL431 power supplies and two twin parts space on PCB for each C-CCS, so all supporting role actors are there. Terrific specs are motivation, sound results end goal, will do the homework. ;)
It's not...Higher impedance M-Ohm would make it so...ideal CCS better option. difference is like bouncing a ball on a soft wooden floor and on solid concrete. One rattles the building and is felt everywhere. Both floors bounces the ball one just bounces the ball better..:)
