Hi Weskoki,My amps are finally working thanks Roberto!
well..i'm happy for you. a photo no?
Hi,Hi, Roberto
as alternative to kit-1, what do you think of Kit-2 combined with DPS-500 ?
Ah... well, such as dual mono, this is an interesting coupled, whereas SDA-400 has a very high efficiency (800mV-1V loses at 4R) and the DPS-500 is a drop in the burst, in the range of 400mV-1V at 500w , this means that with + /-58v, we have> = 56V on load 4R (390W). felt great in Italy this pair. you can not get this ratio V / Power out, with other modules.
The DPS-400/52V, I measured 2.7 V drop below 300W burst. sound very good result.
The DPS-400, is available at 36V, 42V, 52V. (230V) as KIT8. 130€+22€
The DPS-400/LV availlable at 42V,(52V only x SDA-400) (120V) as KIT10 (includes:2xDPS-400/42V+2xPBTU3-S 2x10.000uF). 160€+22€
The DPS-500/DA at 39 - 42V,ADJ on board. (110/230Vac) 105€+22€
Guys... these smps are excellent!, well-tuned for audio amps, with advanced tools for measurements,as it is right to do, not only vout and load test, this is a big difference.
Pinnocchio 1xKIT-3 (120Vac), 2x DPS-500/DA, 1xKIT-10
CafèNoir 1xKIT-8 (230Vac)
Mr.X 1xKIT-1 (230Vac)
Giannettino 1xKIT-1 (230Vac)
We417 1xKIT-3 (230Vac)
Tinitus 1xKIT-1 (230Vac)
Hello AP2,
Do you still have many of these kits? I will be constructing a few amps (Marantz clone as well as the VSSA through hole from PMI) and would want to try your SMPS. I am in Canada so would need the 120V versions.
Thank you.
Bertrand
Hi Royber,Thanks for your interest.
Well, I have a promotion in limited supply as 20pcs in general,( no problem out of promotion)
Depends on the application, you can use the DPS-500/DA (honestly incredible performances) or the new dps-400/120. unregulated but much better than a 400VA with 2x47000uF. in bursts, and sustain of voltage.
Both have a very clean output.
KIT-1 : http://www.diyaudio.com/forums/atta...11-sda-400-professional-multi-way-kit-1-c.jpg
KIT-2 : http://www.diyaudio.com/forums/atta...-400-professional-multi-way-sda-400-kit-2.jpg
KIT-3 : http://www.diyaudio.com/forums/atta...a-400-professional-multi-way-sda-400-kit3.jpg
DPS-500 : http://www.diyaudio.com/forums/atta...sda-400-professional-multi-way-dps-500-da.jpg
KIT-8 : http://www.diyaudio.com/forums/atta...professional-multi-way-dps-400-kit8-42v-2.jpg
Royber 2xKIT-10 (42V/120Vac)
KIT-1 : http://www.diyaudio.com/forums/attac...ay-kit-1-c.jpg
KIT-2 : http://www.diyaudio.com/forums/attac...-400-kit-2.jpg
KIT-3 : http://www.diyaudio.com/forums/attac...a-400-kit3.jpg
DPS-500 : http://www.diyaudio.com/forums/attac...dps-500-da.jpg
KIT-8 : http://www.diyaudio.com/forums/attac...kit8-42v-2.jpg
Noforte 3xKIT-8 (36V/230Vac)
Hi AP2,
Can you please add me to the list:
audionootje 2x DPS-500/DA + heatsink
Audionootje 2xDPS-500/DA + heatsink
Royber 3xKIT-10 (42V/120Vac)
Hi, Update photos. (Real HeatSink on DPS-500/DA magnesium powder)
final appearance of the DPS-400/LV (120Vac) & PBTU-3S (2x10.000uF)
Info on GB:
This GB is open until November 10, after this date, just the time to send and then from November 15, I'm very busy for the testing of new products...EVA incluse ..
Many thanks to those who have joined with confidence, I am sure that many will thank me, when hear the result of this work.
Info on GB:
I tried to upload photo with no success.
Try later. sometime (as now), the forum not allow the upload..
Pinnocchio 1xKIT-3 (120Vac), 2x DPS-500/DA+HeatSink, 1xKIT-10
Info on GB:
- Vendor's Bazaar
- SDA-400 Professional multi-way
