Ryan's Pensil 10.2 Build Log
frugal-phile™
Joined 2001
Alpair 6 (M to match the signature of the 10.2s ) - will work in as small as less than 3 liters, vented - I very much like them in the "milli" sized box (don't ask me the full length name)
A6.2M works in 1.5 -3.6 litre (the 1st pass of the large one (CGR) in the photo Chris posted, on the left, in natural BB on the granite & chrome stand). The vent in the smallest so large that the gross box volume is not much smaller than the universal uMar-Ken6 (2.5 litre, accomodates either A6.2 with no other changes)
dave
Yes the 6.2m looks like the way to get the range I want out of a small speaker. Is that only offered in the copper color? She was hoping I could match the cone color and wood species.
I could always change species, a dark walnut would look great with that copper color.
The uMar-Ken6 is the perfect size.
a flock of millis here with FE127E
cherry / port(colored cone/EnABL), walnut/natural (natural cone/EnABL), walnut/dark walnut stain(colored cone/EnABL) , cherry/natural(natural cones, stock)
the current colors of Alpair metal alloys are the "gun metal grey/silver", and copper - the A6P paper is actually bluish - but can actually be colored - Dave will have a picture somewhere
Then there's the CHP70.2 "natural" (i.e. tan) paper (similar to the raw color of the Fostex above) - softer on the top end, but even more easy to color over a wider range -
The mMar-Ken6 (milli) is much bigger but I could get away with it. Can you guys compare the approx frequency response of the mMar-Ken6 and the uMar-Ken6? I'm going for f3 in the 60s.
Dave can address that one
frugal-phile™
Joined 2001
I'd have to look at the sims to do a guess. F10 might be 60, F3 is likely closer to 80.
A6.2m does not work in a milli (the box is too big) -- only the paper.
Both drivers work in the uMarKen.
dave
I get F3@64Hz and F10@50 for the 6p in a milli size sim.
jeff
as much as I'm not a particularly big fan of "the numbers" (way too many years of listening to all sorts of gear that simply didn't sound as good or bad as the measures or price would suggest) - those are silly good for such a tiny driver and enclosure - of course the downside is excursion/power limitations
They're numbers based on numbers, you have to start somewhere.
Amazing speakers for the desktop.
High-passed, they would make a killer 2-way.
jeff
