That's what happens when you rely on ABX tests instead of what musicians hear openly.
Don't you have some other fraud to hype? I'd think that your business partner's scams could use a little more pumping. The key to it is focus- don't spread yourself too thin.
*yawn*
se
I've been a party to tests that showed guitarists could not identify the amp that provided their perfect sound if they couldn't peek.... So, as you say, just human too!
And then there's the old "I was EQing the mix for an hour until I realize the EQ wasn't patched in" which I have heard many times anecdotally as well as firsthand.
se
Yeesh. Been there, done that. Shoulda bought the T-shirt.
Yeah. I think that's some sort of rite of passage for audio engineers.
se
Why yes, that's correct actually.
-- Jim
Except when musicians don't make good critical listeners, do you really want me to go back and find how many times you have stated this? Or maybe we could revisit the tests where professional guitarists and luthiers were basically agnostic on pickups and pre-amps (741's were as good as anything else).
Who all is going to AES this Fall? Scott, you going to be there?
se
LA, not a chance.
This is interesting.
So there's not even placebo stuff in there?
I think the magic placebo smoke was released when John cracked it open.
se
Back in the early 70's, I worked with rock groups, and for sure, they could hear differences in electronics. They, at first, even rejected some of mine. Then, I got my act together, and they loved my electronics.
In 1976, I worked on a solid state guitar amp for Gibson. We found that the jfet input IC's definitely sounded better than the uA741, but later the 'bean counters' put the 741's back in, because they were cheaper, and a GOOD design (to my ears) failed in the marketplace with the professional guitarists. Gee, what do you know? '-)
You forget all that matters is the sound when it is driven 50% over the rails.
https://www.youtube.com/watch?v=mZGNTx6SrrE
I wish I had $149 to burn but at the moment I do not. Was wondering if I might be able to take up a collection in order to obtain one and give it a full analysis. SY could do a fair bit on the basic unit and I've asked Tyll Hertzens if he could run some measurements using an actual IEM. In the end it could be cracked open to see exactly what is inside.
se
se
Scott, we had active compressor circuits for that, not the main preamp stages. Those without experience should not judge.
Unless you have something to say specifically about the REV33, take it to the Blowtorch thread and stop thread jacking this one.
se
Me, a thread jacker? Wow! No, just a corrector of common mistakes about the audio listening experience.
And then you woke up.
se
Many years ago I smacked up a passive LCR notch filter to chill out what I perceived as a response peak in a pair of otherwise nice sounding Sony headphones I owned. I tuned it to about 2.5 KHz, which I have subsequently learned is pretty much the frequency at which my ear canals resonate. I've read that everyone has this canal resonance to some extent, usually in the 2-4 KHz range. I wonder if this thing is just doing something like that? I would certainly list reduced listening fatigue as one of the sonic benefits of the filter thing I built.
-- Jim
-- Jim
If that's what it's doing, it's completely different from the claims they make on their website. In fact, they vehemently claim that it's doing nothing to the signal itself, but rather reducing the distortion and noise inherent in all earbuds, IEMs and headphones.
se
- Member Areas
- The Lounge
- REV33: Here's some snake oil for you to sink your teeth into
