REV33: Here's some snake oil for you to sink your teeth into
Not everywhere in the world. In some countries patent simply means existing knowledge which a powerful person wishes to appropriate for his own exclusive use, or complete nonsense which someone sincerely believes and the patent officer can't be bothered to check.
One of my favorite patents is the patent issued to John Bedini for his CD "clarifier."
In his patent he claimed that simply spinning a CD in a fixed magnetic field not only rearranged the data on the CD, but it also performed data compression.
He "proved" this in the patent by taking a Kodak PhotoCD, copying one of the files off it into a directory on his hard drive. Then he "clarified" the disc, which again simply involved spinning it in a fixed magnet field, and then copied the same file into a different directory on his hard drive.
However instead of comparing the two files that he'd copied over, he first pulled each file into a graphics program and exported them out as PostScript files.
Then he pulled the PostScript files into a text editor. He noted that one file contained more lines of text than the other, hence the "clarification" had performed data compression. He then did a comparison of the two files and found differences, hence the data had been rearranged.
I took a graphic image and pulled it into my graphics software and exported it as a PostScript file into two different directories. I didn't do anything else. Then I looked at the file sizes and they were different. Ran a file compare and found numerous differences.
The PostScrip algorithm simply produced different files when exporting the same image.
Bedini was a total Froot Loop. But he got his patent.
se
Some IEEE publications contain a section at the back giving brief information on recent patents (probably mostly US patents). I was astonished at the trivial things and well-known things which were included. It seems that you can take well known technology, arrange it in some way which has not been patented before (although such arrangements are routinely used by engineers, and may even appear in texbooks or other publications), invent some claims and then get a patent. The innovation seems to be in the claims, not the 'invention'!
The patent lawyers retained by our company tell me that in their estimation that around 90% of patents would fail a proper legal challenge.
But then you have to factor out the cost of the legal challenge. For some it's simply short money to get claims allowed, once issued the nuisance payoffs out of court can add up to a tidy sum. Patent trolls are worse than even the wire hucksters.
This is interesting.
