Yeah, I got confused between the schematic posted above, and some of the other claims. It would be interesting to see some test results of this thing, but I'm not willing to part with the dough either...
Won't take one for the team, eh?
se
Anecdotal info - no, it's not science but it was interesting. When doing the guitarist tests there was one guy - stunningly good player - who was 100% he could tell his valve amp from a solid state one designed - and measured - to sound the same. So, we swapped the guts of the amps... He saw what he thought was his amp, and said - sounds perfect, better than the other one...
My experience too, but more recent, lol.Back in the early 70's, I worked with rock groups, and for sure, they could hear differences in electronics. They, at first, even rejected some of mine. Then, I got my act together, and they loved my electronics.
Guitarists and bass players in particular are very sensitive to any change in timbre, and are very definite about preferences.
Vocalists are very sensitive about mics and monitoring, but usually have to work with sub optimal setups.
Any improvement to monitoring is very much appreciated by vocalists, and very much allows improvement in their performances.
Improvement in floor wedge monitoring allows improved PA room sound, and improved IEM's further allows the vocalist better control and expression.
In a sense, monitoring is the most important reproduced sound in a performance.
I have ample experience with production talkback headphones.
In this application I am listening for spoken/shouted cues from the lighting director.
During a loud show, I have bleed from the room sound getting through the fully enclosed headphones.
Then the director opens his boom mic, and I additionally get reproduced room sound, and then I have to accurately discriminate his voice through all this cacophony.
When a show is loud I have to turn up my beltpack volume to get over the room sound, and the SPL at my ears can get pretty extreme.
Talkback beltpacks run on a phantom powered party line system, ie hundreds of meters of balanced mic cable daisy chained through each crew position.
These beltpack amplifiers run into limiting/clipping just when you need them to be clear and articulate, and it can be bloody hard work to understand what is being shouted into a mike when the beltpack is hard into limiting/clipping and loud.
After such a loud show, my/our ears can be fatigued, ie cooked.
This gadget claims reduction in noise, and mentions filtering HF junk.
Any improvement to IEM sound is good, and vocalists will favorably respond.
What is the problem here with this product ?.
Dan.
That it appears to be a fraud of the same sort as one fashion audio accessory after another. Dubious claims, check. Pseudo-science gibberish, check. Outsize price, check. Lack of any performance data, check. Glowing encomia by fraud promoters like Lavorgna, check.
John and you jumping in is one more data point in favor of the fraud presumption. The only thing missing is the "military secrets" part.
They are also generally non-technical, incredibly superstitious and easily let by others, hence the 'I have to have this mic'.My experience too, but more recent, lol.
As you are talking intelligibility then 1-4khz is the range of interest in which case a roll up above there and steep roll off above 10k would seem to be a good thing. Nothing snake oil and certainly not high fi.Talkback beltpacks run on a phantom powered party line system, ie hundreds of meters of balanced mic cable daisy chained through each crew position.
Dan.
$149 retail is not expensive for a product that evidently works.
Bear in mind that development costs have to be amortised in what is a relatively limited market...but of course you already knew that.
This gadget reduces harm to peoples' ears, I say good luck to the makers of this device.
Dan.
Dan.
Paying the least talented member of black eyed peas to say it's amazing is not proof that it 'evidently works'. Unless you are completely gullible. You're not a musician are you?
Rubbish.They are also generally non-technical, incredibly superstitious and easily let by others, hence the 'I have to have this mic'.
Talkbacks are bandlimited to vocal band.As you are talking intelligibility then 1-4khz is the range of interest in which case a roll up above there and steep roll off above 10k would seem to be a good thing. Nothing snake oil and certainly not high fi.
Dan.
Look around the web, you will find pro audio forums positive experiences.Paying the least talented member of black eyed peas to say it's amazing is not proof that it 'evidently works'. Unless you are completely gullible. You're not a musician are you?
Dan.
I wish I had $149 to burn but at the moment I do not. Was wondering if I might be able to take up a collection in order to obtain one and give it a full analysis. SY could do a fair bit on the basic unit and I've asked Tyll Hertzens if he could run some measurements using an actual IEM. In the end it could be cracked open to see exactly what is inside.
se
I got $ 50. Any other takers?
Dan.
To quote SY, the plural of anecdote is not data. Placebos work, we all know that.
Rubbish.
Most rock guitarists have to employ someone to tune and setup their guitars. I could also swamp you with anecdotes from interviews that show that Brian May is an extreme outlier (along with Coxy).
Dan.
So this magic dodad will do nothing even if it did something except in the case of horrendously distorted amplifers, in which case the problem is somewhere else.
You have to be kidding, I though we already had someone say it's a very well potted nothingness.
I'll go in, provided someone carefully documents the deconstruction.
I already told the story, famous female vocalist lent a one off prototype of an array of 31 of our MEMS mics custom built for us by an "S" company. Exactly, "I have to have this mic", and the sales rep couldn't refuse even though that was not the plan.
You're invited to participate. We did a pretty good job with the Synergistic Research HOT until the forum where we documented this removed those posts and edited others (SR is apparently one of their advertisers).
Well, there's the "try it for 30 days" -- though that may fail when it's returned as a kit....
Shipping damage. ;-)
se
- Member Areas
- The Lounge
- REV33: Here's some snake oil for you to sink your teeth into
