Hi QH, because I'm using this power supply I have to cut a trace on the amanero board and desolder a component, right?
hi!
fist you need run normal supply from computer.
when all work well, you can cut track for remove 3.3 v from computer
use 3.3v from dac for usb!
thanks
Hello
will this system work with ES3098EQM?
yes, you can use for ES3098EQM, but you need change R/ iV
thanks
Hello, is it still possible to buy a bare PCB for +HV/-HV/Filaments Power supply?
yes!
pm to me! thanks
yes!
pm to me! thanks
Hello Quanghao,
i sent you a PM about that, but didn't receive any answer...
Hello Quanghao,
i was reply you many times!
thank your advice!
quanghao
thank your advice!
quanghao
Very strange... i didn't receive your messages...
Hi JPDuarte and all!
yes, i have 2 option PCB
1. Pure i/V balance with: 2 tube 12AU7+ 2 tube 6DJ8
2. Pure I/V SE with 3 tube 12AU7
3. HV supply for Pure i/V use one
Now you can see schema off Pure i/V SE and par list! thanks
quanghao
PM: and some information about it with: Algar_emi post #217 DAC ES9038 PRO GR 2
Just a noob question: in se (3 tubes) schematics, what is the function of v3b triode? I see its anode does not output to any v2 triodes grid...
So a single 12au7 could be used for both channels, using only one triode per channel, i.e. the one that outputs to following tube grid?
More, sorry Quanghao but i didn't receive any message from you, something has gone wrong...
- Group Buys
- Pure Tube i/V for ES9038PRO-9028, 9018, AKM...
