Can anybody enlighten me what Gary has in mind? Art numbers, datasheets?gary s said:2. Connection points for AC and DC should be screwdriver terminals - the nice heavy three way types are good or faston terminals.
Has anybody a clue of max size of the caps? Diam 40 mm? Brand?
10000 uF/63V/35 mm seems to be max for normal types.
Hi P-A
For the AC and DC connection points I was referring to PCB mount terminals with a screw terminal for the external wire connection.
The Phoenix Contact type MKDS-10HV (for example) is rated at 600v and more than 70 Amps with a 10.16mm pitch. A lot of other companies make these types, some have pitches of 5.08mm for the PC lands for lower voltage and current ratings.
I think a space on the board for 40mm dia standard 2 pin Snap - In capacitors is great with a 10mm PC land spacing. This way people can use a wide variety of brands of capacitors that use this industry standard pin spacing. You can get up to 47,000uF at 40VDC in this size and at least 22,000 uF in 63V. If possible I would want 4 of these caps per rail.
Gary..
Gary..
Phönix 6.35mm
This terminal will take 4 sqmm (AWG 11)
I'm thinking of using 9.5 mm pitch because then I'll can use spade connectors also.
BHC 15000 uF / 63V
No ALC10A153EF063 Size E
The footprint on the pcb will also take standard 10 mm snap-in
What have you in mind for max size of plastic caps?
BHC 15000 uF / 63V
I'll noticed that www.elfa.se has the contact in mind but the price is freightning. I'll check directly with Phönix but I'll prefer if the parts are easily avaible.peranders said:I have Farnell as source so the Phönix MKDS-10 is excluded I'm afraid. 4 sqmm seems to be technically OK. 16 sqmm is a bit overkill I think.
I'm kind of like these huge Phönix connectors and I have asked for a price directly from Phönix. I'll hope that most of you guys choose this connector.
As you may have noticed I'm doing a total remake of Jan's efforts. My goal is to make it more universal when it comes to parts.
The schematic is ready. I wonder though if I should use those huge pcb connectors. They are also rather expensive and must be ordered directly from Phönix. As you can see I have separate rectifier bridges. The caps are BHC Rifa-Evox. The fuseholders will take both 5x20 and 6x32 mm. The board will have the caps in vertical rows in order to get the board not so long.
How many connections are necessary? 2 Channel amp?
Schematics here
Schematics here
Please check the schematic carefully and come with opinions. Check also the wiki page. Correct if necessary the amount of boards you are interested in. Notice that there is no lower limit for this group buy. I will run it anyway but it would be nice to freeze the design as soon as possible.
Hi peranders
Some questions.
Is this type of supply really the best choice for a high power main amplifier?
Ground problems if more than one channel is connected to these type of supply?
No problems with two of these supplys in the same box?
Give me a name of a good functional commercial or diy amp built in this way.
Make me relax please.
regards
Some questions.
regards
Ragnwald, this PSU is perhaps more than a regular PS since you can insert an inductor or resistor inbetween the caps. The rectifiers are also more than average.
The design is a bit universal therefore it's not optimized to suit only high power amps.
The ground connections need special attention. I'm aware of that.
Can think of any amp with such a PSU as this one.
Hi P-A,
The PCB is looking fine, with the added flexibility of 3 legged diodes. I can use TO-247's, MUR's or HFA's now.
One last question before I join the group buy, where can I find the specification of the heatsink 6100BG Aavid? Sometimes it may be extremely difficult to locate suitable heatsinks for putting onto a custom-made PCB.
Thanks.
Thanks.
The heatsinks are standard, easy to get.
http://se.farnell.com/aavid-thermal...to-220-202-9-c-w/dp/1213466?_requestid=316325
Lot's of brands Aavid Thermalloy, Austerlitz, Wakefield Engineering etc.
- Group Buys
- Power Amp PSU Board (for e.g. LYNX Amp)
