Pictures of your Tubelab amp
Just finished a Tubelab SE build with 45s. I used a wooden wine crate for the chassis:
--TWH
The previous content of this crate was great too, I guess :)
Great Idea!
The SSE Sounds Great - thanks George
I've just finished my first, but not last for sure, Tubelabs build. With George's design and all the info on this forum - it was a joy. Had to post a few picts. Hammond PT and Choke, Edcor OPT. Running EL34 right now but plan on rolling tubes soon.
Tubelab SSE by Sgrilli AD
Hello all, here is my SSE!
This is my first tube amp project and I am very proud of it. Few people can say "I did it" and now I can. I've built the second, the Tetra Sans All in One phono preamp.
I thank George for the project and the Tubelab site information and to many people in this forum, as rkinze, boywonder, Ty_Bower and others who helped me to achieve success in the project.
Here in Brazil we don´t have the DIY culture and we have all difficulties to buy electronic components, because almost everything has to be imported and the conversion value of the dollar plus customs rates are too high. Any simple design is very expensive.
The SSE is running with the following configuration:
- Schatz 375-0-375; 200mA - Power Transformer - Brazilian made (similar to Allied 6K7VG)
- Schatz 15-8-5K - OPT - Brazilian made (similar to Edcor GXSE15-8-5K)
- 100 uF motor run auxiliary cap
- Triad Magnetics C-14X
- Obbligato Film Cap 0.22uF / 630V, Premium Gold
- UL/Triode Mode Switch
- SS/Tube Rectifier switch
- CFB Disable switch
- Cathode Resistor Switch with selection of 750, 560 and 490 Ohm
- EH KT88, EH 6CA7 Big Bottle and NOS Russian 6L6 tubes
As you can see in the pictures, I built the SSE with the sockets soldered out of the PCB and modified the layout of the tubes to be aligned with the auxiliary capacitors. I used some extensions to connect the sockets with the PCB.
I have used much the KT88 in UL mode with CFB and the sound is very nice, clean mids and crystal clear highs. My main source is a vintage Sony turntable running with Tetra Sans Phono Preamp.
I still need to solve a problem with my loudspeakers, because I'm using a DIY fullrange with Audio Nirvana Super 8 and the bass are not suitable.
Thank you all.
Antonio
Hi Bob,
The bass response of the fullrange is not good, is weak and without depth.
I made one BR model of 43 liters and follow all of the drivers manufacturer's recommendations.
I had some discussions in this forum. See the Thread. Posts 9; 10 & 23.
I installed the filter recommended by Scott Moose and the result was noticible. But I believe I can go further.
I did some tests with my subwoofer in passive function, connecting through the entry "speakers" and the result was very good. So, I think the SSE is able to produce enough bass.
Although it´s not my preferred alternative, the use of an active subwoofer puts everything in order.
Antonio
Hi Folks!
Just completed my Tubelab SSE. I call it "The Valvustein".
This are the most relevant components:
Power transformer: Hammond 374BX
Output Transformers: Hammond 125 ESE
Choke: Triad CX-14
Motor Run Cap: QE 80uF
Coupling caps : PIO K40Y-9
Electrolitic caps: Nichicon and Nichicon Muse
Rectifier Tube: TAD GZ34
First stage amp tube: JJ ECC81
Output tubes: Tung-Sol 6L6G shoulder type envelope (shown in picture) and JJ EL34
Potentiometer: ALPS 50KOhm
Chassis: Douk
Wired in single-ended triode mode. Sounds great!!!
Thanks for watching!!!
