Pearl Two
diyAudio Chief Moderator
Joined 2002
Its not only they shift the arm cart resonance to a more "optimum range". The "ballast" plates are probably having a damping effect on the cartridge mounting end also. Anyway since you are a Pearl user don't forget to let people know how it went for you here in the end.
Hello, Mr dB. I have an OL counterweight and a structural upgrade. I don't know if it's any heavier, as I never had a stock one to compare. Yes, it's said that 103R prefers heavier arms. Although, a little note, it's compliance is measured at 100Hz and there are many happy users with RB300 tonearms. It gives me a hint that it still can be a good match.
I don't know how it works with the Origin Live weight, but with a DL103R on a standard RB300 with the standard sintered tungsten weight, to balance the cartridge you'll have to pull the weight out to where the first O-ring is about to pop off the end. The optional Rega heavy counterweight is more than sufficient though.
Joined 2011
Of course. I'll let you know. Although, I'm taking my time with a TT build so it won't happen that soon. In the meantime, here are my voltages to compare.
Joined 2011
Try 1K trimmer connected as rheostat instead of R28 and trim for 1.5V across R6 first. Then see again with P1. Your LED is higher than 1.7V Vf most probably.
Q3 is squashed for Vce in your annotated schematic measurements. Try 15-22 Ohm R21-24 to give it breath. Your input quartet IDSS is probably higher than in the original.
Should I try that too?
Joined 2002
Not the trimmer as you can make yours show near 0V at that node as it works now. About input stage higher R21-R24 resistors is up to you to test if you can hear any better. It works at 26mA and lower Vds now instead of 20mA as drawn, but it works. You should restore to 10K R10 first if trying with more R21-24 value.
I swapped out a 1k pot for R28 and attempted to trim the voltage across R6 to 1.5 v. When I first turned on (Pot at R28 ~ 500 ohm) voltage was around 3.0 v and I was not able to lower it to 1.5 v - only about 2.0 v. I put a second DMM on the junction between R16 and R17 and the voltage was very high around 18 v. By trimming the Pots at both R28 and P1 and observing the 2 DMMs, I was able to get 1.5 v across R6 and around 0 at the R16/R17 junction - although it was varying quite a bit 200 ms at the junction. I did not spend a lot of time observing.
I let it burn in for a few hours and went back to measure again. Voltage across R6 was still 1.5 v, but the voltage at the R16/R17 junction point had moved up to around 1.2 V. I observed for several minutes and found the voltage readings varied a lot - 125 mv to +1.3 V - very unstable. It would stabilize at a point for 10 seconds that vary up down for another 10 seconds, then stabilize, vary, etc. Voltage at R6 would stay stable and only change if I adjusted either Pot.
I connected the TT and amp and once again got very load buzz at moderate volume - brutal noise that says something is really wrong!
Any other ideas for next steps?
Here are my measurements against Wayne's.
Start at the beginning, the voltage around Q3 is wrong, once sorted move on to the hum problem.
In Wayne's circuit the JFET's are drawing 20mA, bnorrish your circuit is drawing 28mA, adjust the value of R9 to 330R or 360R to compensate 10V/0.28mA=~360R.
Seberia has the same problem.
Do you have hum at the collector of Q3?
Are the ground prongs of the XLR jacks grounded to the cases? The ground floats on mine.
Hum would be too subtle a term! Keep in mind I have a working channel with very similar voltages on the front end. I may go back and tune after I fix this channel. No music very load buzz
How would I check hum at collector of Q3? I do not have a scope, yet.
