meaning... ?and difference is quite big
that the speakers are resolving and accurate or...
fussy?
Let's go give it a try .
Overall I think it will be sounding good, not perfect, but maybe .
Updated with the "original" adjustable spikes.
Only the base plate I changed to 10mm, original looks like about 5mm.
Baseplate can be screwed to bottom of cabinet, holes can be added.
I think so too!Overall I think it will be sounding good, not perfect, but maybe .
Updated the plan with 26mm solid wood panels.
Including sawing plan with standard wood panels 2500 x 610 x 26 mm panels.
Sawn the 26mm solid Oak panels.Updated the plan with 26mm solid wood panels.
Thickness each about 33mm (1mm surplus to finetune later).
The next step is to glue the slats against each other alternately.
To do this, I marked the ends of the panels with a marker.
wouldn't it be easier to just go to Home Depot?
https://www.homedepot.com/b/Kitchen-Countertops-Butcher-Block-Countertops/N-5yc1vZcgrc
[yes, tongue firmly in cheek]
Nice work.
Nice work.
The idea is to make the best possible copy of the original.wouldn't it be easier to just go to Home Depot?
Nice work.
Some progress with the cabinets.
Very stiff and heavy assembly already.
Panels with some mm overlenght.
Later perfectly sanding to each other.
- Full Range
- Pearl Acoustic Sibelius
