oneplustwo F5 build thread
Hmm... well, the two MOSFETs on this channel both read 45. And both on the other channel read open. So where does that leave me? :confused:
BTW, thanks to everyone for all the help! Hopefully I'll have something to show for all your input shortly.
If you follow the schematic, you will see the drains (middle pin) going to ground through R1/R2 and R5/R6 (at least), so it should read something (when the hs is grounded). But that >something< should be the same on all output devices.
Joined 2004
If the other channel is not grounded (either through 'proper' ground, or through the mounted hs) then it should read open. Are you following along on the F5 schematic?
I only mentioned checking output device to hs to make sure you did not have a short, and it appears you don't, so you should be OK here.
Gotcha, thanks for that.
I am trying to follow along with the schematic... but to be honest, my understanding is rather pedestrian. Maybe I can get help with your comment regarding "proper" ground. Both channels are mounted to the heat sinks the same way. So I would expect the readings to be the same. The only difference is that the current channel is also connected to the PSU PCB which is connected to the heat sink through the aluminum plates. Does that make a difference and if so how? In my mind, those connections are outside of the loop that would define the resistance from the middle pin to the heat sink.
Apologies for the questions... I do want to learn so any help would be appreciated. (I guess I should have paid more attention in my EE classes... that's why I'm a mechanical engineer though!)
6L6
Moderator
Joined 2010
At this point in the game you should have NO wires attached from the PSU board or the amp boards to the chassis. None. They should all go to some point that eventually attaches to the CL-60 ground loop breaker.
Oh, your link didn't bring up the right photos so we have to go back and look through them. It's hard to see how you have it grounded.
Ok, sorry for confusing matters. Let me try to clarify.
There are no wires from the PSU board or amp to the chassis. But I thought that the standoffs connected the boards to the chassis. There is a place on the PSU board for the cl-60 which I have populated. And I have a wire that goes from the ground on the PSU board (its under the board) back to the speakon jack to take to the PSU enclosure where it is attached to the earth ground.
Let me try turning the pots the other way and see what happens first. Maybe there I no issue?! Fingers crossed.
Ok... For some reason, it appears we're semi-good. The light went out this time as I was futzing with the trim pots. The only other thing that changed is that I connected the input and output wires.
Anyway, removed the bulb tester and went through the bias process. New issue:
I only get about 240mv of bias before I run out of trim pot travel. I got DC offset near zero.
It seems to be drifting upwards. Actually, it's at 250 already in the last few minutes. Perhaps this is the same issue 6L6 had with his build?
6L6
Moderator
Joined 2010
Do what I did in these pictures -
I had 2.2k resistors on hand, that's what I used. One channel has 4.4k total, one has 6.6k total.
I have a desoldering gun thing so I can probably replace the resistor entirely without too much risk of lifting a pad. As pretty as your execution was. :) I think I can find some resistors in the 6.6K range. I know I have some 10K. Is there a downside to going to high? Perhaps just less sensitivity from the pot, but that seems like not such a big deal.
6L6
Moderator
Joined 2010
Only add enough to get the Fets to bias properly. If you add too much you won't be able to turn it down enough...
Once it's working you could replace the resistor with a single one of the proper (whatever worked) value.
