Is there much interests in Omni-Directional loudspeakers out there?
Please post.
I'll start with One of the well-known DIY designs
PLUTO-2.1 omni-directional loudspeaker
Please post.
Not DIY but looks amazing nonetheless
German Physiks - High End Technology Loudspeaker Manufactur - DDD Driver - THE LORELEY MK III
The Pencil
This used to have pics of the great design, utilising a pencil case - True to DIY spirit
http://www.diyaudio.com/forums/multi-way/112904-pencil-inspired-ohm-micro-walsh-tall.html
The SoundSphere
Model Q-15 Loudspeakers
High power, high fidelity foreground music with enhanced low frequency response and high SPL capability in single or multiple speaker systems. Ideal for gymnasiums, ice rinks, churches, swim centers, open public areas, bars and nightclubs.
Soundsphere // Omnidirectional Loudspeakers & Speaker Systems
The Visaton Fontana:
And don't forget to look for the Fontanella Sats too.
Thanks for the reference -- those were mine. I wanted to point out that the graph is of the vertical response variations. Horizontally there is virtually no response variation due to geometry.
Also, shouldn't leave out the most famous of the omnis:
MBL:
Duevel:
Omnis can sound very good, but there is a problem if you want a wide sweet spot -- you can't toe them in! So, for front channels, at least, I've moved to Controlled Directivity designs.
Raal Requisite.
Celtic Obelisk
Obelisk - Celtic Audio Ltd.
A smooth acoustic response from 28Hz to over 20KHz brings an uncanny degree of realism to the sound, be it music or voice. Careful attention to phase and timing accuracy only made possible by our active processing coupled with the omni-directional radiation of higher frequencies brings the performers into your room and allows you the freedom to hear the same clear reproduction wherever you choose to sit (or stand!)
Beolab subwoofer
Most if not all subwoofers are omni directional anyway (except that they fire halfspace). But this is neat !
Bang & Olufsen BeoLab 11 - HiTech Review
Due to the omni-directional properties of the bass, the performance is not dependent upon orientation; therefore the unit can be ‘rotated’ as desired when positioned on the floor.
Altec Lansing
Altec-Lansing | iTech News Net - Gadget News and Reviews
The bias for aesthetics are clearly evident like placing the loudspeakers that close to the wall.
Dlneubec's The Mentor omnidirectional project
HTGuide Forum - Omnidirectional Speaker Project, any interest, help?
http://htguide.com/forum/attachment.php4?attachmentid=8513
el`Ol Omi-Dipole combo
http://www.diyaudio.com/forums/multi-way/101658-my-omnidirectional-project-3.html
How would that sound? Curious.
Zemi orb speaker
Cute !
http://blog.paran.com/blog/detail/postBoard.kth?pmcId=blue5191&blogDataId=33893133&hrefMark=
Cute !
- OMNI Gallery
