NP D1 DAC clone with enhancement
If you have soldered the D1V3, I think not likely unless you want to de-solder all the parts.
Anyway I believe all the expensive items like DIR9001, SM5842 and PCM63 are in sockets and they can be re-used back in D1V33.
If the D1V3 is not soldered yet, then most of the D1V3 parts can be used and only new pcb and jfets are required. Also some capacitors and resistors are different in D1V33.
