Just finished latest update. Did some improvements to netname changing.
It now changes all netnames in the schematic that are meshed with the current netname under change.
Murton-Pike Systems
Murton-Pike Systems
Software prints name of nets on pcb tracks while laying out pcb.
CDROM
PCBCAD51 pcb cad design software 2017 version | eBay
DOWNLOAD:
Download and software key for PCBCAD51 pcb design layout software 2017 version | eBay
CDROM
DOWNLOAD:
You can now drag and drop recently used components on to the layout.
CDROM
CDROM
Christmas special now only £4-99 PCBCAD51 download and software key.
Download and software key for PCBCAD51 pcb design layout software 2018 version | eBay
Response has been good to this so might carry it on into new year.
Download now allows updates without overwriting library files.
So you can always keep up to date with the latest version.
Latest update available at:
pcbcad51 | eBay
pcbcad51 | eBay
Latest version is now out.
The advantage of a download is you can download at future dates and get the latest version.
http://www.pcbsoftware.xyz
After a few requests for a demo version I have made one.
PCBCAD51 demo version
Download from:
http://murtonpikesystems.co.uk.servepreview.net/pcbcad51demo.html
Instructions on web page.
Regards Nigel
Download from:
Regards Nigel
A major revision is out now for July 2018.
The software now displays schematic and pcb components when searching libraries to make it easier to see what you are choosing.
You can now drag and drop components onto schematic and pcb.
PCBCAD51 pcb design software
I have added 1,000,000 samples per second PC USB oscilloscope to the website.
Murton-Pike Systems
Murton-Pike Systems
I have a new USB oscilloscope design.
Murton-Pike Systems
PC USB digital storage oscilloscope. Up to 1,000,000 samples per second.
Good for about 100KHz sine wave.
Time bases are 250uS 1mS 5mS 10mS 50mS
In *1 probe mode max input is +/-3.3 volts. In *10 probe mode max input is +/-33 volts.
In *100 probe mode max input is +/-330 volts.
Voltage range is 63mV, 125mV, 250mV , 500mV, 1v and 3 volts per division for *1 probe.
Voltage range is 630mV, 1.25V, 2.5V , 5V, 10v and 30 volts per division for *10 probe.
Voltage range is 6.3V, 12.5V, 25V , 50V, 100v and 300 volts per division for *100 probe.
Positive trigger, negative trigger or no trigger.
Trigger level can be set using cursors keys.
Single shot display or roll multiple times display
. Measuring markers to measure voltage and time between two points.
Has an AC/DC switch.
Comes with software on a CDROM.
Save/load traces. Print to printer function. Save trace to bitmap file.
It needs a *1/*10/*100 scope probe and printer A-B USB lead which are not included.
Powered by USB bus.
Simple FFT display for displaying frequency content.
Murton-Pike Systems
Powered by USB bus.
Nigel,
That is very cheap for such features. Is there a demo version available?
Frank
Download from:
Regards Nigel
PCBCAD51 price is down to £4-99 for download for Christmas and New Year.
Click here for web page. Murton-Pike Systems
2019 full versions of PCBCAD51 and PCBCAD360 are out now.
Murton-Pike Systems
Murton-Pike Systems
Hi Nigel,
I bought the PCBCAD51 and it didn't work on my laptop. You refunded immediately and I thank you for that.
I use a Dell 15" laptop with i7 and have monitors also attached, one though the HDMI port and the second through a Dell DA100 USB to HDMI adapter. Is this possibly why software froze the laptop?
The software is just bog standard win forms C# and I don't do anything unusual in the software.
Yours was the only one it froze on out of about 3000 sales.
I occasionally get anti virus problems but other than that the software is usually well behaved.
You could try it with one monitor and see how it behaves.
- Vendor's Bazaar
- Nigel Wright's Vendor Thread
