adamus said:yes, the 1m resistor is to ground, no series resistance, output goes through 4.7uf caps as the pedja buffer does present large dcoffset.
thanks for the feedback Adamus!
Joshua
longitude said:Lu,
Just bought your kit,
Before the kit arrival,
I would like to prepare the power supply,
Can you tell us how much is the total current demand of the whole kit?
Thank you!
.5 amp http://www.diyaudio.com/forums/showthread.php?postid=1724702#post1724702
glt said:
Thank you!
So a single LM317 can do the job~
Good news~
adamus said:Lu, finished the build. Its a good product.
I used a buffer after the vol control to lower the output resistance.
Wooooooooooow What a wonderful job !!!
Hi guys,
Thank you all
Thank you for choosing my KITs
The kit is available for a long term, and the total cost are 70 USD /100 USD for single-end/balanced version, worldwide shipping included.
For I am not a full time DIYer here, your orders will be send in each weekend.
My email / MSN : bbp6604560 at hotmail .com
regards
Lu
Thank you all
regards
Lu
Notice:
Hi TC,
Your parcel is on the way to HK, I sent it with sf-express,which website is www.sf-express.com
I also sent the tracking number to your email,but the KIT will arrive in Hongkong tomorrow, for the telephone problem, you'd better contact the local SF-EXPRESS if you can't get the parcel in time.
regards
Lu
Hi TC,
regards
Lu
coloradosound said:Could you make available balanced multichannel (6 or maybe
even 8 channels) and with source selection for more inputs
(perhaps 10 input sources)?
Hi coloradosound,
Multichannel is OK, up to 8 CH is not a problem, but 10 input ...
Re: Re: board dimension
Hi Lu,
I just received the package today, thanks.
BTW, I haven't applied the power yet still busy building the case but by looking under magnifying glass I can see you've done a good soldering joint there...
Joshua
bbp said:
Hi my friend,
sorry to reply you late.
Your parcel is on the way to you ^_^
regards
Lu
Hi Lu,
Joshua
Re: Re: Re: board dimension
Have a nice time in DIY
joshuajoshua said:
Hi Lu,
Joshua
Re: more details please
Hi billy, email sent
veiloctane said:hi i have sent email requesting more information.
i am new to diy audio and currently looking for a remote control volume control with source selection for my 41hz. amp6-basic.
thanks,
Billy
bbp, Been using the R2r a lot, its a great piece of kit. My only gripe is the range with a relatively hot source.
are the 'steps' log or linear? component wise, is there anything i can do to give more control at the lowest volumes (-65 to 60 are big jumps).
For info, the attenuator is buffered (unity gain).
