NEW Audio amplifier kits, modules and many others.
I guess it's a IRAudAmp7 IRS2092 ?
Considering SMPS from Roberto P (AP2 from audiopower.com Italy) model DPS-500-S with classdaudio.com SDS-258. I hear great things regarding SDS series amps!!!
Has anyone here used AP2 SMPS with SDS-258?
About to do a DIY 2 chan rig with the latest and greatest "Cheap and Cheerful"
Current list is:
Jed Kunz Dynamic 4T SE DIY towers
Emotiva XDA-1 DAC (also used as pre)
SDS-258 amp with DPS-500-S SMPS
Comments, hints and suggestions?
The class T amplifier has their own sound characteristics, and just some class D amplifier can reach this. if you need just low power, a TDA8920 amplifier is the way to go, or a TA2022 which has more power that you need, but can be supplied at lower voltage and there will always be a power reserve to get the best dynamic.
If you are referring at this amplifier Connexelectronic then i can say that the sound is similar, and there is more power available, especially for the higher power versions.
hi there Cristi,
I got 4 300va 2x50vac torids so that would give +-70-75v dc rails after rectifier.
I'm wondering what IRS2092 modules would work best with this power supply setup?
or is there a better module for this setup?
I'm also wondering what size power supply is used in the ta3020 module with inbuild smps?
I bought TA2022 from you (connexelectronic) and after few months of working its starts to smoke.
Supply is AC 23V-0-23V, speaker is subwoofer with two times 8 ohm. Speaker link:
Dayton SD215-88 8" Shielded DVC Subwoofer
Here are some pictures of amplifier.
http://www.shrani.si/f/3J/OJ/343iQ1bQ/1/dscf3846-copy.jpg
http://www.shrani.si/f/3g/EX/3anhy9Tv/1/dscf3849-copy.jpg
http://www.shrani.si/f/F/AP/2YDzsh5e/1/dscf3852-copy.jpg
http://www.shrani.si/f/z/PG/4HJOXZbU/dscf3855-copy.jpg
What should I do?
Thank you,
Robert
What should I do?
Thank you,
Robert
Are you running the voice coils in parallel?
The speaker might be spec'd with 8ohm voice coils but in reality they will be nearer 5-6ohm, once you parallel them you can end up with a lower impedance than what the amp is rated at (2 to 3 ohms). Iv'e had this situation myself, but haven't had such a spectacular burn out like the one you are showing in your photos, usually the on-chip over current protection kicks in and mutes the amp. Might have been a faulty chip.
If you want to be running 2-3 ohm loads though you should be looking at proaudio amps or stuff that is rated to take the current.
col.
What should I do?
From what i see in this pictures the IC is broken for sure. must be replaced and clean the tracks before soldering the new one.
using the amp on subwoofer only would boost the rails voltage due pumping above the maximum voltage, if the input is not connected 180* out of phase and this is the most probable cause of the damage.
send me your address by mail to send you a new ic, or if you can't fix-it just send it back, and i will repair the board or replace if is too damaged.
when you bought it ? contact me by mail for details.
col.
I run one coil per one channel so 8 ohms two times
