Banned
Joined 2002
rabstg said:
I would buy a complete "kit" of parts to build a pair of Mini-A's. But in order to stay true to the patent, you would be obliged to sell just the PCB's at cost too.
The boards will be at cost..
GreatThe boards will be at cost..
Now to something else, (we dont want any kind of the chipamp war here do we?) I was looking over the psu board of Brians.
If making a CRC filter, what would be a good starting point for the R? Value and wattage.
Steen.
Banned
Joined 2002
Quote is back.. Guy's..
Hi Jason,
double sided, 0.062" thick, 2 oz final copper thickness. blue solder mask and white legend.
set up and plots...$200
E-test..................$150
100 pcs...............$7.00per pc
150 pcs...............$6.25 per pc.
Jason, the set up, plots and e-test are one time charge. if you order the same boards again these are not charged again.
So this is 100 pcs x $7.oo = 700 Plus 200 Setup plus Etest = 1050 CDN / 100
$10.50 each board.
So in total for 2 boards it is 21.oo Canadian Not including shipping.
Next id like to add Parts order Maybe. And brian's famouse Power supply board..
Any interest's Now. ?
Hi Jason,
$10.50 each board.
jleaman said:Quote is back.. Guy's..
Jason-
The E-test is not required and can be waived. I think Brian has already tested it with his SMD version with the exception of the balanced input section. The $200 set-up is required "only" because of the V-scoring on the boards but can be reduced sometimes as much as 50%. Don't roll over for their first quote.
I'm still in, and still prefer a "kit" with parts too.
rabstg said:The E-test is not required and can be waived. I think Brian has already tested it with his SMD version with the exception of the balanced input section. The $200 set-up is required "only" because of the V-scoring on the boards but can be reduced sometimes as much as 50%. Don't roll over for their first quote.
I never get electrical test. I have been told that it is really not needed unless the boards are 4 layers or more.
As for the kits, a digikey parts list can be provided for easy ordering.
As far as the board quote, I will send JasonL a version with 2 channels on 1 pcb and he can see how the price is different.
Brian
Banned
Joined 2002
Banned
Joined 2002
Banned
Joined 2002
Mark A. Gulbrandsen said:This might take me an evening or two as I need to experiment with the sandbox page first. I will play on that tonight and then try to get it put up for tommrrow night....
Mark
I heard the word Wiki, and decided to create one:
http://www.diyaudio.com/wiki/index.php?page=miniALEPH+PCB+Group+Buy
but the it seems to be having server problems, and I couldn't finish editing it. Hopefully a moderator (AF probably will need to handle it) will look into this soon.
Brian
Banned
Joined 2002
- New Aleph Mini PCB GB
