25Vac supply is good for both 8 ohms and 4 ohms load, right?
For 4 Ohm loads it's better to use 21-22V secondaries, 25V will work but will clip quite easily.
I have been following this project for long enough. I'm in as well.
Welcome
I am hoping these will sound as good as I think they will running my Altecs.
I suppose it depends on your expectations... BTW I'm confident you'll be satisfied.
I've just signed: +1 kit for me!
Thanks for the effort
You're welcome, Daniele
So we're at 40 kits -> price dropped down to 30€/kit
When are you closing the GB? For 5€ it is not worth waiting another 1-2 months.
It's also for this reason that the GB will remain open until the end of February...
I'm thinking to set a deadline for next Sunday just to have a date.
OK, great.
I'm building these to go with the amps: DTQWT-mkII
As you can see from the impedance measurement it's roughly 6 Ohms at it's lowest. Sensitivity is very high at 95 dB/2.8V so power shouldn't be a concern. Apparently they play loud even with 4W.
I have ordered six 225VA 22-0-22 Toroids from AirLink Transformers to go with the kits.
Thoughts?
Lastly I would like to give a huge "Thank you" to Dario for your work. I almost feel bad coming in at this late stage where all the hard work has already been done and simply take advantage. I promise to write a detailed build log!
/kazam
Thoughts?
/kazam
Wow! It seem than more than one partecipant registered on DIY Audio to partecipate to this GB, am I wrong?
I would guess they will mate just fine.
You're welcome
The build log will be welcome as well
You're welcome
Is it possible to get a kit with the SMD components on board. I'm afraid my shaky old hands could never handle those little guys.
It's posssible but it will not come free...
SMD parts will cost 16€ more + work
PM me to talk about it.
does it better to use 2 separate enclosures or one is fine for amp ?
Your choice, one enclosure is perfectly fine.
Thank you. Would you be so kind recommend which would better suit boards and tranny from modu.it website ?
Slim 02/280 for easy loads or Dissipante02/300 for heavier dissipation.
I've bought Dissipante.
- Group Buys
- My_Ref Fremen Edition Interest/Group Buy
