My MOSFET amplifier designed for music
Beautiful work on the single output pcb.
Could we please have the Gerber?
Thank you !
Thanks!, Here you go sir!:)
regards
Prasi
  • mooly mosfet amp prasi_rev2.1_fb res_single pair_Cu_Bot.pdf
  • mooly mosfet amp prasi_rev2.1_fb res_single pair_top silk.pdf
  • mooly mosfet amp prasi_rev2.1_fb res_single pair_2018-09-13.zip
One hint for potential builders while populating the power resistors with Vishay MRA-10 or any other with a diameter of ~8mm.
The middle one (R23) can be raised slightly above the other 2 (R24 &R26), I think 3-5mm would be sufficient. R24 and R26 should be raised above the PCB board by 3-5 mm anyway.
This would ensure proper heat dissipation.
regards
Prasi
Hello Mooly,
Could you post a delay and DC protect circuit suitable to this amplifier here (35v to 45 v PSU) if you have it? I can make a small pcb which can be mounted on the speaker terminals that also includes the 6uH inductor//10ohm 2W resistor.
For PSU, a single 300VA dual secondary trafo (2x25VAC or 2X 30VAC) along with a single CRC board like Project16's with 22kuF-0.22R-22kuF would suffice the stereo requirements?
This would enable potential builders a complete build package, that they can consider undertaking the project.
These are just my thoughts, you may suggest doing it differently.
regards
Prasi
Hi Prasi,
I have just made a speaker protection for the Quasi because I am not ready to connect expensive speaker to transistor amplifier without protection (of course with tube amplifier there is not such a risk because the output transformer block all DC voltage )...
Here is a bad picture and the schematic but it has not been tested yet !
Rgds,
Marc
  • Schema Power and Protection.pdf
I've no hard copy of the DC protection and delay circuit as I used a combination of Doug Self's switch on delay from the 'Precision Preamp' from 1996 and his DC offset protection circuit from his famous Blameless Class B. Later on I replaced the mechanical relays with discrete solid state versions.
Post #260
Output Relays
Post #273
Output Relays
ok, i will have a look.
Hi Prasi,
Rgds,
Marc
Hello Marc,
this is most helpful.
Lets see, if I can make it so that it can be mounted on speaker terminal.
regards
Prasi
A good friend asked if its possible to make it as a single pair output and reduce the length to less than 100mm to take advantage of low board costs from China:cheerful:.
I gave it a try and here is the result.
It has the same features of the earlier board (caps, resistors, etc, even the logo;)).
regards
Prasi
Mooly, Prasi,
Understand that this project has been ongoing for a long time (a decade!) and lot of developments have been made - apologize in advance for the noob questions :):
- What is the power output (in watts) of the amplifier with 2 pairs of outputs and designed for 45V rails (post My MOSFET amplifier designed for music.)
- What is the output with single pair of output devices with lower voltage power rail?
