My AUD600 Rev3.0 is suitable for any type of filter core like T106-2,ETD,EE & EI core with gap and supply voltage range will support like +/-35V to +/-85V and IRFP250N will support fsw up to @500KHz range with cool.my only problem was HF little low (using ETD,EE,EI with gap)compare to LOW and MID,but it is satisfactory.I am not started the PCB yet.
MANOJ
Hi Manoj,
This sounds very promising...guess I'll have to wait for rev. 3.0 then, but please let us know if it will be shared for DIY'ers in the forum.
Thank You!
Hi ALL,
My AUD600 Rev 1.1 change to Rev 3.0
First test fsw @460KHz with IRFP250 MOSFET run cool with Mid Volume temp 50 deg. with full drive @ 4 Ohms load.
MANOJ
MANOJ
Manoj Sir,
Pictures of your Amp shows that your work is very neat and clean.
Great Work Sir !!!
Pravpa
Hi ALL,
MANOJ
Manoj Sir,
Great Work Sir !!!
Pravpa
Hi Manoj,
use accurate LCR meter to measure the value of your inductor. maybe your ee type filters don't have enough inductance to reach a good cut-off freq. also as i calculated before , in lower loads , we lost some higher frequency and we should increase cut-off freq.
Hi IR,
Thanks. I changed cut-off freq. settings ; add a 474/400v capacitor now HF is good.
MANOJ
Hi all,
anyone have CAMCO Vortex 6 amp schematic
i got one for repairing and i don't have schematic.SORRY FOR THIS,its not a class d it is a class H but it had a power full SMPS(60A). anyone have pls share
MANOJ
Hi Manoj:
You Can try this link:
Service manual, eprom result list | ElektroTanya | Service manuals and repair tips for electronics experts
Raj
Hi ALL,
MANOJ
Very Impressive!!!
Hats off!
Raj
hi manoj i found this fet irfb23n20. will it work comfortably with aud 600 or ir900,ir1k5 with +/-90vlts at 2 ohms?
Hi stewin,
it will not support 2 ohms @ 90V supply
MANOJ
Hi ravpreet,
check PM. i already send part list
MANOJ
Hi Manoj.
You can send me the list of components and wiring diagram of AUD1000C?
Thank you for your cooperation.
luizcpimenta@yahoo.com.br
luizcpimenta@gmail.com
Sir,
This AUD600, has already been tried and test by Mr. Manojtm, and he found it's results are satisfactory.
Pravpa
Thanks.
MY 1000W RMS Design
MANOJ
Hi Manoj.
You can send me the files of this amplifier?
Thank you.
Interested fo AUD1000C
Could you please post the schematic of AUD1000C,
Thanks in advanced
Syaelend
Thanks in advanced
Syaelend
Hi ravpreet,
here it is
MANOJ
Hi sayelend
i don't have shema for this .it was my old design with carrier based class d amp +/-90v supply
regards
manoj
- Class D
- My class D amp
