My class D amp
My AUD600 Rev3.0 is suitable for any type of filter core like T106-2,ETD,EE & EI core with gap and supply voltage range will support like +/-35V to +/-85V and IRFP250N will support fsw up to @500KHz range with cool.my only problem was HF little low (using ETD,EE,EI with gap)compare to LOW and MID,but it is satisfactory.I am not started the PCB yet.
MANOJ
Hi Manoj,
This sounds very promising...guess I'll have to wait for rev. 3.0 then, but please let us know if it will be shared for DIY'ers in the forum.;)
Thank You!
Hi ALL,
My AUD600 Rev 1.1 change to Rev 3.0
First test fsw @460KHz with IRFP250 MOSFET run cool with Mid Volume temp 50 deg. with full drive @ 4 Ohms load.:):)
MANOJ
Hi Manoj,
use accurate LCR meter to measure the value of your inductor. maybe your ee type filters don't have enough inductance to reach a good cut-off freq. also as i calculated before , in lower loads , we lost some higher frequency and we should increase cut-off freq.
Hi IR,
Thanks. I changed cut-off freq. settings ; add a 474/400v capacitor now HF is good.
MANOJ
