MPP
Joined 2005
PCBs have arrived......
I had a short conversation with Hesener. He did not design a pre-regualtor board so far so this has to be build the old fashioned way at the moment. If enough interest comes maybe i can persuade him to design a board for this too, or is that something for you Bksabath ?
I am hapy to do aniting I can.
But seeing hesener design and first batch of pcb one would not certanly spoil thing by going cheap and nasty.
I can do protos for personal use and one off boards.
But when is time to go for the full build I would not buy one of mines..:D
Could you send me SCH and component specs I can have a go at it any way.
It was posted by Frans somewhere here.
Maybe Frans should post the pre regulator section alone.
We have to agree on a power transformer. I think Frans prefers toroids.
I will look out for some.
Yes I do
I always get my transformers from Cybertron
Or:
http://www.amplimo.nl/images/downloads/ds standardrange/18016.pdf when using one
http://www.amplimo.nl/images/downloads/ds standardrange/08016.pdf when dual mono (prefered)
Yes I do
Frans.
P.s. When using toroids you should alwais put them in a separate metal (iron) box and that box should include the mains filter!
r-core...
r-Cores are cool
r-core transformers
and you do not need the 'extra' metal (iron) box, but I would still do that.
The main point about the transformer is:
25VAC 400mA (minimum) for stereo or 2 transformers of 25VAC 200mA (minimum) for dual mono (preferred).
Frans.
P.s. I still do like the dynamics of toroids (and will use them (toroids that is) :))
