Cool, cooler ... coolest. Actual picture of the actual board
Dear Joakim hesener
I may be jumping the gun and still would like to be beta tester for first build.
But if one set is available and or + critical component kit is an option I would be very interested to get one
Could you let me know either way?
Joakim hesener
Hi Bksabath, you have PM. by the way, Joachim and myself are two different persons last time I checked ;-))))
That must be in the new 4th edition that came out this year. I do not have that circuit in the 3rd. edition.
So he follows, not leads... ok.
_-_-bear
I had a short conversation with Hesener. He did not design a pre-regualtor board so far so this has to be build the old fashioned way at the moment. If enough interest comes maybe i can persuade him to design a board for this too, or is that something for you Bksabath ?
Sorry Intended messagge to you both shuld have been Joachim / hesener or even hesener / Joachim
Tanks for PM
You got one back
I am hapy to do aniting I can.
But seeing hesener design and first batch of pcb one would not certanly spoil thing by going cheap and nasty.
I can do protos for personal use and one off boards.
But when is time to go for the full build I would not buy one of mines..
Could you send me SCH and component specs I can have a go at it any way.
It was posted by Frans somewhere here.
Maybe Frans should post the pre regulator section alone.
We have to agree on a power transformer. I think Frans prefers toroids.
I will look out for some.
Yes I do
I always get my transformers from Cybertron
Or:
http://www.amplimo.nl/images/downloads/ds standardrange/18016.pdf when using one
http://www.amplimo.nl/images/downloads/ds standardrange/08016.pdf when dual mono (prefered)
Yes I do
Frans.
P.s. When using toroids you should alwais put them in a separate metal (iron) box and that box should include the mains filter!
r-core...
r-Cores are cool
r-core transformers
and you do not need the 'extra' metal (iron) box, but I would still do that.
The main point about the transformer is:
25VAC 400mA (minimum) for stereo or 2 transformers of 25VAC 200mA (minimum) for dual mono (preferred).
Frans.
P.s. I still do like the dynamics of toroids (and will use them (toroids that is) )
